EGR necessary?
Do we really need an EGR valve on the car?
or can it be removed and plugged?
Re: EGR necessary?
as long as you don`t need to pass emissions, go ahead and plug it. Also to keep the egr sensor code from popping up, all the ecu needs is a reading that the sensor is in place unless it is a california car.
Re: EGR necessary?
why emissions?
i'm putting in a stage 2 ecutune ecu so will that still matter?
Re: EGR necessary?
The stage 2 should not have an effect on emissions but blocking the EGR will. They won't notice that it's blocked but your readings may not be within specs. With a '92 do you still have to do smog tests in Ontario?
Re: EGR necessary?
my car's a 94, parts car is 92, and yes we need to do an emissions test every 2 years kinda gay. supposedly it was supposed to be for any car under 14years old but they cut it off at anything 87 and under doesnt need it.
Re: EGR necessary?
What's the point in blocking out the egr?
