Old 02-10-2010, 01:41 AM
Gamesy's Avatar
Gamesy Gamesy is offline
how wide is too wide?
I was looking into doing a widebody mod to the car but the car is already fairly wide. My question is how much wider should the kit be?
Old 02-10-2010, 02:23 AM
Re: how wide is too wide?
Gamesy, I can understand a widebody on the front end of the car, but they will look ugly on the back end. Unless you modify the METAL, I do not recommend you mod the rear fenders.
Plus you have a rare blue SVX, I wouldn't touch it if I had it in that color.
Old 02-10-2010, 03:18 AM
Gamesy's Avatar
Thanks for the input silver, i'm i'm about 80/20 for doing it (80 not doing) :P
As for the color i'm gonna be doing a repaint at somepoint down the line and will try to color match as best to laguna as i can, if not i think KONA blue would be a good choice for the future.
The only plans i have for bodywork is restyling the front bumper and maybe attempt the rear to make it look like that newer rear end everyone's been talking about.
Other than that i'm still on the fense of whether to tune the engine or leave stock and just do a good sounding audio. Either way this summer i'll be making new fiberglass sub boxes for the trunk.
Old 02-10-2010, 07:04 AM
shotgunslade's Avatar
anything wider than stock is too wide.
Old 02-10-2010, 08:36 AM
Splinter Splinter is offline
The steel widebody on my impreza cost around 13 grand to have done at a shop
Something like 200hours labour
Unless you're a very experienced bodyman, don't try it yourself, and even if you are, get a crap car to practice on before you ruin yours.
http://forums.nasioc.com/forums/show...1655704&page=4
Starts at the bottom of the page, if you want something for reference.
Old 02-10-2010, 01:45 PM
Farang's Avatar
Farang Farang is offline
Dmitry
Nunquam Non Paratus
Old 02-10-2010, 01:50 PM
Farang's Avatar
Dmitry
Nunquam Non Paratus
Old 02-10-2010, 02:22 PM
Gamesy's Avatar
thanks for the reference pics farang. ya might pick up an old civic beater and screw around with it. :P
Old 02-10-2010, 03:57 PM
ZMan's Avatar
ZMan ZMan is offline
Very nice job Farang - I guess your "never unprepared"
Old 02-10-2010, 04:08 PM
scoobymal's Avatar
scoobymal scoobymal is offline
Those cars/number plates are in the UK? some sort of custom car meeting?
The work seems to be of a very high high standard
Old 02-10-2010, 04:53 PM
the_paynter the_paynter is offline
ur only thinking this because i told you im doing it :P haha
1992 SVX: JDM STI short geared 6-speed swap, COBB short shifter, slotted cross drilled rotors, Smallcar Clear headlight lenses, 1997 Grill.
1992 RHD WRX: EJ20G, 16G, Cusco Coilovers, Wilwood 4pot/2pot brakes, Defi Genome 60mm gauges, Exotic speed downpipe, 3.5" A'PEXi spec GT catback
Old 02-10-2010, 08:41 PM
Gamesy's Avatar
lol i've been entertaining the thought of doing it to a car i just havnt thought of which. My inspiration came from Alpine's Build on the Sinister6 BMW
http://www.youtube.com/watch?v=wTnH3vKhyps
and this subaru concept
http://www.egmcartech.com/wp-content...erings_003.jpg
Old 02-10-2010, 10:42 PM
Wow, I just watched that youtube and I highly respect the work he did on that BMW (even though the outcome is a little ugly).
But remember, this car is for show only, any small hit on the fiberglass and it will crack where metal meets FG.
Always remember, metal on metal, plastic on plastic and FG on FG. THERE IS NO OTHER WAY.
Old 02-11-2010, 01:32 AM
Farang's Avatar
I don't remember where I have found these photos. May be it was on English GT-forum. I liked techniques.
But remember.......
I absolutely agree
Dmitry
Nunquam Non Paratus
Old 02-11-2010, 02:06 AM
Elliott's Avatar
Elliott Elliott is offline
It doesn't even need to be a hit, temperature changes are more than enough since they expand and contract at different rates. I don't care how good glues and resins get, it will always crack eventually.
