Old 12-17-2017, 07:48 PM
carlhoffmann carlhoffmann is offline
What is this pipe ?
Just wondering what this pipe does as its split , is it a vacuum advance ? and what does it do ? would it effect my engine running rough ?
Old 12-17-2017, 09:06 PM
Tireiron Tireiron is offline
Re: What is this pipe ?
That's the vacuum line for the fuel pressure regulator. That break will make the car run like crap. Replace it with new vacuum line.
Old 12-20-2017, 12:48 PM
thanks for the reply
Old 12-30-2017, 10:36 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Hey Carl, think you need to clean the engine bay .....
