Old 12-04-2015, 09:05 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Engine block plastic parts (p/n required)
I am looking for the plastic pieces that locate on the block and hold in place the HT leads down the length of the block, mine are shot & 1 is missing.
Each have "C" shapes in order that the HT leads slide & get held in place - side by side along block length.
Each plastic piece has 2 location pins, that clip into the block.
The ones between 1 & 3 / 2 & 4 mount flush to the block.
The ones that are at side/rear behind 5 & 6 have a bevel in order to aid with directing the HT leads from the side to the rear of motor.
Part numbers & availability would be great to know - my part manuals are currently boxed in a storage unit.
Thanks
Steve (in New Zealand)
Old 12-29-2015, 02:47 PM
SURTEESS's Avatar
Re: Engine block plastic parts (p/n required)
ignore the previous post - I got the pieces from www.zebraupickcarparts.co.nz - there was a 92 that looked in really great shape - no rust that I could tell?.
Old 12-29-2015, 09:01 PM
When you say "HT" are you referring to the coil pack wires?
Old 12-30-2015, 11:36 AM
theflystyle's Avatar
Opposed forces in addition to the factory manuals are a great resource for part numbers.
http://opposedforces.com/parts/svx/
1994 SVX LSi
2008 Legacy 3.0R
Old 12-30-2015, 02:18 PM
SURTEESS's Avatar
Yes sorry that is what I meant = coil pack wires.
Would still like to know p/n..
TIA
Old 12-30-2015, 05:01 PM
Although I am not much help, I too would like the p/n's. I installed all new coil packs and through the purchase process was unable to find the coil pack wire place holders. Perhaps they are only available in the engine seal kit?
Old 12-30-2015, 09:28 PM
dbarnblatt's Avatar
From the factory parts catalog:
Clip No. 4 - 24233 AA330 - drivers and pass sides
Clip No. 4 - 24233 AA340 - pass. side rear
Old 01-01-2016, 01:51 PM
SURTEESS's Avatar
So you are saying that there are 3 required in total ?
Old 03-31-2017, 12:18 AM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
Part number 24233AA340 (pass. side rear) is now NLA.
Sam
Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners
Old 03-31-2017, 09:25 PM
lsupcar lsupcar is offline
What about the other one?
Old 04-01-2017, 07:10 AM
gwynethh's Avatar
gwynethh gwynethh is offline
Make your own out of 1/2" thick nylon? (The upper clip mounting holes are actually metric threaded.)
"Peace is the flower of justice."
