Old 10-29-2007, 03:49 PM
cruisen_15's Avatar
fuel pressure regulator
im not sure if its good or not but i took the vacum line off it and it didnt do a thing but make the engine idle higher, still ran like crap?? is this vacum line really even needed??
Old 10-29-2007, 03:52 PM
Evil One Evil One is offline
Pinto Boosting Freak
Send a message via AIM to Evil One Send a message via MSN to Evil One Send a message via Yahoo to Evil One
If it works like most I have run across, yes you do.
At idle there is a vacuum on the regulator, it leans it out and also reduces fuel when in higher vacuum situations such as part throttle cruising.
It will hurt fuel economy, potentially foul plugs, and mess with your AFR.
Jim
1992 Dark Teal LS-L with 4.44 swap. NC Plate "EVIL I" *Dont Fear the GEAR*
1977 Ford Pinto baby blue with 79,000 miles
Old 10-29-2007, 03:54 PM
cruisen_15's Avatar
well if my symptoms stayed the same with the vacum line off could it be that my regulator is bad??
