Old 10-17-2007, 02:58 PM
johaun johaun is offline
Tranny Fluid Leaking into Differential
I have had the transmission out 2 times now, and the problem both times was transmission fluid squirting into the differential. i have tried replacing the bearing and the O-ring in that area, but that doesn't seem to be the problem. Any suggestions on how to solve this problem?
Old 10-17-2007, 06:18 PM
SUBBYRU89's Avatar
SUBBYRU89 SUBBYRU89 is offline
Siren of the Pleiades
Send a message via AIM to SUBBYRU89
Did you replace the seal tube?
14.708 in the 1/4 mile pre-KillerWail
'89 XT6 Pearl White~JuiceBox (Project)
'92 SVX BoverP~Peej (Down for the moment) 1st Stage II trans installed by AWD,15 & 20 min mods,...
Old 10-17-2007, 09:40 PM
NiftySVX NiftySVX is offline
There is a double seal on the pinion gear where it passes through the pump housing. Has to be that or the seal tube, which has to be replaced each time it is removed.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 10-23-2007, 02:16 PM
Thank you, i am not sure if that has worked, but i will find out as soon as i get the thing put back together. that thing is really heavy, lol.
Old 10-23-2007, 02:25 PM
Originally Posted by johaun View Post
... that thing is really heavy, lol.
Yeah, I screwed my back for a few days trying to lift Subbyru's onto the work bench...
She helped reinstall it yesterday, it runs nice. I'll be running it around more tonight, then checking the diff to make sure it's golden.
Old 11-05-2007, 08:48 PM
Talking Thanks!
Thanks for the info. It was the seal tube. I am on the road and the ride is incredible.
