Old 10-05-2007, 05:59 PM
removing camshaft pulley
hey guys, i currently removing the heads off of the svx and am stuck trying to get the pulley off.
I know there is a special subaru tool, but after reading through posts it appears that it is unavailable and even if it is costs about $150!
I also read that others have used an impact wrench to remove the pulley, does this actually work? How does using the impact wrench overcome the pulley still turning (which happens when i try to remove the pulley with hand tools)? Also if the impact wrench does work, how does one go about getting the proper torque specs on the pulley when reinstalling? thanks, chris
Old 10-05-2007, 06:47 PM
wawazat??'s Avatar
Yeah, I'm still around
Hey Chris,
The impact wrench easily took off my cam pulleys. It spins and impacts the bolts so quickly compared to a regular wrench they just spin right off.
To re-install them, I used a strap wrench around the pulley body and my torque wrench to lock them down. A little bit of a hassle but not too bad. I'm sure other will chime in with how they handled this and I'm eager to see what they did.
Todd
Down to none
Old 10-05-2007, 07:22 PM
tom, thanks for the info! I actually did a little more research on here and found that there is a universal cam adjuster that should do that trick...
Lisle 38220 Universal Cam Adjuster I just d that and found a bunch of sites offering it.
Old 10-05-2007, 10:31 PM
SVXdc's Avatar
SVXdc SVXdc is offline
Radio wiring harness guru
Great find! I could really have used that a couple of weeks ago. Will it work on the crankshaft pulley too?
Here's the older thread that mentioned this tool:
Cam and Crank Pulley Tool
Even though I had my radiator out, none of the many impact wrenches a friend had in his shop would fit — they were all too long, even with the shortest socket. We searched online and around town for a short-throw impact wrench, but couldn't find one.
Ended up doing the "wrench holds one camshaft pulley bolt while you loosen the other pulley" trick. A little scary, because I wanted to re-use my timing belt, but it worked out OK.
Others have used that trick, but with the old timing belt just prior to installing a new one. When you know you're not going to re-use the old belt, you can even lock it tighter onto the cam gears with vice-grips.
I used a strap wrench to re-tighten each cam pulley without too much difficulty.
David C.
Old 10-06-2007, 06:38 AM
David, i will be buying the tool today,i'll let you know if it works on both the camshaft sprocket and crankshaft pulley. In the past to remove the crankshaft pulley i would just insert a service bolt in the flexplate.
Old 10-06-2007, 06:43 AM
SomethingElse's Avatar
word words wording
I hope it works well. I'm running out of spare pulleys. sweet find
Eric
Old 10-20-2007, 04:05 PM
Well the Lisle cam sprocket remover is a success, i highly recommend it! although the actual removal of the sprocket (the RH side sprocket) (after the bolt was removed) was a pita! Just thought i'd let you all know.
Old 10-20-2007, 05:50 PM
SVXdc's Avatar
My crank sprockets lifted right off once the bolts were removed.
So did this tool work for the crankshaft pulley also?
David C.
Old 10-20-2007, 08:25 PM
david, this tool would NOT work with the crankshaft pulley. This tool only works on the camshaft sprockets (LH and RH exhaust camsprockets). To remove the crankshaft pulley i just put a service bolt in the torque convert, worked well for me...
Old 06-01-2010, 10:01 AM
doug maire doug maire is offline
keystoneaz
Re: removing camshaft pulley
I made a crankshaft pulley removal tool out of 1/4" plate steel.
It cost me about $60.00 to mfg.
If anyone is interested in using it I will send it to you for the cost of postage and when your done with it you can send it back to me.
It uses either a 1/2" or a 3/4" Breaker bar and is compact in design so it will be a small package to ship.
Old 06-01-2010, 02:05 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Cool Re: removing camshaft pulley
Why not add some dimensions to the part picture, then a few people could chip in at various points around the globe & make some - to share with others...
Old 06-01-2010, 02:22 PM
keystoneaz
Here you go, You don't need the larger 3/4" hole a standard 1/2" breaker bar is sufficent.
Old 06-01-2010, 02:24 PM
keystoneaz
Sorry, file attachment did not load.
Old 06-01-2010, 03:10 PM
SURTEESS's Avatar
Doug,
thanks will help others
