Old 12-25-2007, 04:05 AM
subbieatnz's Avatar
SVX stero removal?
just wondering how i would go about getting the SVX stero removed form my car?
thanxs
1989 Vortex 6 Maroon
1983 RX Silver Grey
Old 12-25-2007, 04:26 AM
SVeXy96's Avatar
SVeXy96 SVeXy96 is offline
Sold my soul to Subaru
Its pretty easy. When you park the car leave it in gear (the shifter is in the way in park) and pull the emergency brake. Pop out the ashtray and there is a plastic frame around the whole console with 2 small screws underneath it and I think you have to take the door off too, but I don't remember. But if you have some diff size screwdrivers and just poke around a bit you'll figure it out
Old 12-25-2007, 06:47 AM
Everything you need to know, with photos, can be found here:
http://www.geocities.com/svxdc/AudioInstall.htm
Old 12-25-2007, 08:02 AM
Ownbot's Avatar
Ownbot Ownbot is offline
I'm the anti-do-gooder
Smile
The link Svxcess posted is spot on. All the color codes for the wires are exactly right. Some artard cut my connector off for the stereo so I had to match everything up. It's pretty easy to remove just be careful to not scratch anything. And make sure you slide the cardboard in the sides when pulling it out, otherwise it gets stuck on the trim.
Old 12-25-2007, 06:08 PM
processengr's Avatar
One thing to be careful of selecting after market speakers, is the type with the coax tweeters mounted above the level of the speaker, as these will interfere with the factory grilles. The grilles can be forced over them as they have some flex, but the speaker will vibrate/resonate the grilles and panels at certain frequencies.
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 12-28-2007, 02:08 PM
SVXdc's Avatar
SVXdc SVXdc is offline
Radio wiring harness guru
Originally Posted by Ownbot View Post
... Some artard cut my connector off for the stereo so I had to match everything up. ...
I wouldn't rag on the previous owner too much. Up until I started selling harnesses a few years back, none existed so a "hard wire" install was the only option.
I do also have the "reverse" harness, if you want to restore the factory plug
David C.
