Old 01-08-2008, 03:06 PM
crazyhorse's Avatar
242,000 mi on oem trans
A couple things.
When you initially turn on the blower it will likely spike kW. It will also take a second or so to spool up. That will negate your "short burst". I read in here a 450cfm rating. That's not sufficient to feed 3.3 liters, for that you'll need around 550cfm.
I doubt the engine could breathe through the leaf blower, so you'll need an alternate inlet to supply air when the blower isn't running.
I'm in no way trying to be a wet blanket, but this isn't going to net you any tangible gains. In fact, worst case, it will disintegrate, feeding your engine bits of plastic, and aluminum. That would be a fatal case of food poisoning, and you won't like that the EG33 pukes up.
"42"
Current Stable By Age:
Old 01-08-2008, 03:44 PM
cruisen_15's Avatar
the blade its self will most likely not disinigrate do to that it has a function of being a vacum for yard trimmings, therefore it is probably stronger than other blades, it also has a duel design, there are blades on both sides of the wheel shaped blade...
Old 01-08-2008, 03:53 PM
At what RPM have you calculated the quoted air consumption, remembering that a four stroke is involved? Has a final positive pressure been allowed for and if so how much? This latter factor will be the ultimate decider, otherwise all is for nothing.
Old 01-08-2008, 03:54 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Have you calculated how many amps you're going to need to feed that blower?
Please?
Old 01-08-2008, 05:30 PM
cruisen_15's Avatar
ok, i have setup a system where i can see how much psi my blower gives, right now its at 2 psi, i am using a real boost gauge btw... well anyways, the air that is being pressurized is coming back out the way the air is coming in... im going to do some modding to the blower case right now.
Old 01-08-2008, 05:51 PM
Wikedjuggalo's Avatar
Rebuilding
There's a funny video someone posted somewhere about a redneck Booster or something. It was really funny and they used a leaf Blower
Old 01-08-2008, 06:10 PM
cruisen_15's Avatar
ive now gotten near 3 psi since doing a little modding...
Old 01-08-2008, 07:03 PM
LetItSnow's Avatar
What's powering the fan during this testing? If it's AC from the wall, that doesn't count!
Old 01-08-2008, 07:06 PM
cruisen_15's Avatar
aww!!!! i think someone is getting close to prooving people wrong !!!! The more you tell me ill fail the more ill try to make it work so go ahead and tell me its a failure...
Old 01-08-2008, 08:22 PM
LetItSnow's Avatar
Wait, was it plugged into the wall or no?
Old 01-08-2008, 08:25 PM
cruisen_15's Avatar
yes... plugged into the wall , but im not working on the energy part of it right now, just trying to work on the building psi part
Old 01-08-2008, 09:14 PM
cruisen_15's Avatar
ahahaha, im now to 4 psi!!! woot!!! i solved the problem of the air backing up and coming out the inlet...
Old 01-08-2008, 09:47 PM
Understand that any restriction in the air flow will develop pressure behind the point of restriction. A nozzle will provide this on the original set up and will fix the ratio of airflow and pressure for best results blowing leaves.
When the engine is drawing air this will cause a depression in the inlet, increasing with RPM. The blower must deliver more air than the engine draws in so as to develop pressure within the inlet tract.
It must be appreciated that static tests without the engine are useless, other than possibly providing figures for what would be complicated calculations. You must work on the basis of flow resistance, volume of air moved and pressure. Much as you would use resistance, amps and volts in an electrical problem.
You can not design/build for pressure, without considering all three factors.
Old 01-08-2008, 11:29 PM
cruisen_15's Avatar
ok i made a video, sorry its so dark but u get the point... theres a cone filter on it btw, pretty redneck right here
http://youtube.com/watch?v=XYJgJONAMas
Old 01-09-2008, 03:30 AM
JaySVX's Avatar
JaySVX JaySVX is offline
The way that normal turbochargers and superchargers work, is they increase pressure as engine speed increases, at the same time also increasing airflow. Can your setup maintain 4psi at idle? Then, as engine speed increases, and airflow increases, increase, or at least be able to maintain 4psi, or will it drop since the engine is consuming more air? Your electric supercharger will have to be effectively scaled to match the engine speed, the same way a supercharger or turbocharger would, else you're psi is going to drop to 0psi and potentially negative psi once the engine is drawing in enough air.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
