Old 01-07-2008, 07:32 PM
It's Just Eric's Avatar
Missing in action
pardon my being vocal on the matter, but I vote
FAIL!
lemme put it in very un-technical terms for you. The motor in the svx sucks more air in that your leaf blower will make. If for some ungodly reason you managed to flow more air than the motor consumes, you'll run into a new problem. The air mixes with gas to create a combust..hold on, getting too technical... IF you manage to put more air in the motor, you'll need to put more fuel in too. That's why people put on larger inkectors and fuel pumps and fix the computery bits as well
I would dare you to prove me wrong, but you'r best bet is to return the leaf blower before you do something that'll void it's warentee
R.I.P Cool Signature.
Old 01-07-2008, 07:46 PM
cruisen_15's Avatar
too late
yeah, kinda too late to return it... i meen i could but if they took it apart... they would say WTF!!!!!! well does the MAF send anymore fuel if it sees an increase in air going in?
Old 01-07-2008, 09:37 PM
cruisen_15's Avatar
not trying to be a smartass about it after it was said i have a 7 amp blower motor.... its actullay 12 amps thank you
Old 01-07-2008, 10:36 PM
Boxersix's Avatar
Boxersix Boxersix is offline
Porsche Autofanatiker
1 Hp = 746 Watts
Amps to Watts = A x V
12 x 12 = 144
144/746 = ~.19 HP
Rough math and conversion.....but .19hp is not going to cut it
Even if you took that same motor and bumped it to 36V(armature and field windings would never last) you'd only get to about 1/2 hp. Then you run into charging issues, etc.
While turbochargers do not use horsepower from the rotating mass of the engine..they DO require horsepower to spin the CHRA and compress air. They just extract that power from the wasted energy of the exhaust flow and heat. Typical SC's required anywhere from 10-150hp to drive(drag blowers upwards of 400+hp to work at WOT). Your typical turbocharger, pending size and CFM ebing compressed, takes 10-70 hp to drive.
Do you see where I'm going with this?? Your $100 mark isn't enough, unless you're getting batteries for free, and lots of them........
Old 01-07-2008, 11:14 PM
sicksubie's Avatar
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 01-07-2008, 11:36 PM
Davestone's Avatar
Davestone Davestone is offline
Newbie
Send a message via AIM to Davestone
Originally Posted by sicksubie View Post
Ha that made me laugh. Anyways, if you wanna try this, all the power to you. And if it works I want a How-To
Good Luck
David
'94 Laguna Blue L 110,000 5000k Hid's, K&N drop-in filter, leather seats(thanks to mysvxrocks), 350z rims, and now with big dent in rear passenger quarter panel
Purchased 12/2007 and lovin it
[SIGPIC][/SIGPIC]
Old 01-08-2008, 12:03 AM
Logic says one thing and science says another. Which is valid? This is not an area where faith has any relevance, so science must hold true.
fail!
blk 92' LSL w/ average mods
Old 01-08-2008, 12:57 AM
odepaj's Avatar
odepaj odepaj is offline
Killer of threads
fail!
Haha, but in this case, even logic has failure written all over it!
Dustin
-Dustin
Old 01-08-2008, 02:24 AM
Originally Posted by Boxersix View Post
1 Hp = 746 Watts
12 x 12 = 144
144/746 = ~.19 HP
Sadly I agree with certainty that the suggested experiment is doomed to failure. However I do not hold with some of the rather disparaging authoritative remarks as these could be personally hurtful.
From back in the thread it is fairly clear (Typo accepted) that the intended blower motor is rated at 225 volts AC mains power, and now we have 12 amps as an additional figure. A “good power inverter“ has been mentioned as a possible accessory.
As a guide the Figures at issue could be taken to indicate 2,700 watts. Rather high I would have thought for a portable tool intended to use a long extension lead, but quite possible. It should be appreciated that these motors along, with those in vacuum cleaner, can be run at very high levels of efficiency due to a vast amount of cooling intake cunningly utilised.
Calculation indicates 3,6 HP. and not 0.19 HP as has been stated. Surely it is obvious the this sort of squirt would not blow powder from a ladies puff, much less leaves off a garden path.
The correct comment would have been to draw attention to the fact that rewinding the motor for 12/36 volt operation would not be cost affective even if feasible. Secondly that an inverter capable of delivering 2.7 KW is a costly exercise and considerable losses would occur during conversion. Even as an experiment, the figures do not add up.
Old 01-08-2008, 11:49 AM
Nevin's Avatar
Nevin Nevin is offline
I'll make this easy: FAIL.
Jesus is the remedy
2015 Expedition EL Ecoboost
Old 01-08-2008, 12:09 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Old 01-08-2008, 12:26 PM
Boxersix's Avatar
Ah yes correction most definitely needed on my part there with the voltage at hand. Correct math, incorrect variable Still at hand, and as stated even 3.6 hp just won't add up to what he needs to make this work(and be worthwhile financially)
-Adam
Old 01-08-2008, 12:40 PM
cruisen_15's Avatar
ok this motor is a 120v 12 amp. so what im understanding is i need a power inverter that is 2700 watts, well what about this inverter right here?
http://www.amazon.com/dp/B000EWIYQQ?...0&linkCode=asn
yes i know at 5k rpm it would be taking in more air than the blower, but what about starting at 800rpm, and a quick shot from the blower?? wouldnt that work?
My friend also said that what if you use a a/c blower out of a car, and that those run on 12 volts so i should build one of those... but i wasnt sure...
My blower has enough power to shoot a water bottle up in the air... connected to the house elec.
I could show a video of my blower if anyone likes....
Old 01-08-2008, 12:54 PM
cruisen_15's Avatar
ok i ran some numbers, correct me if im wrong..
1 amp * 110 volts = 110 watts
therefore, 12 amps x 110 volts = 1320 watts
then i would only need a 1320 watt power inverter, explaining why my 400 watt power inverter did not work...
Old 01-08-2008, 01:00 PM
LetItSnow's Avatar
The question is, where are you going to get that wattage? From 12-14V, that's a bucket of amps!
