Old 12-10-2007, 02:43 PM
ssnsltd's Avatar
ssnsltd ssnsltd is offline
That's gona leave a mark.
tire PSI- what PSI to use, side wall or door badge/ factory
I have a set of /falken ZE912's and a set of Ecasta's for my SVX'x. I only have a few miles on the Ecastas, the ZE912's go on tommorrow.
the MAX PSI on both tires is 51 psi. I think that is a bit high, but I have always gone with max PSI on the side wall. the tire web site kinda waffles around with an answer but does't come right out and say anything specific.
anyone have an educated opinion on the subject -?
thanks!
david
David
96LSi 102k Laguna Blue
95 LS-L AWD, Safety package, 140k Polo Green
the Chick Magnet:
91 Justy GL EFI 4x4 154k (new motor @120k)
90 Yamaha V-Max
82 Yamaha XJ650LJ Turbo
My Diver Propulsion vehicle:
88 Jeep Cherokee 160k
"U-sta-have"
88 XT6 AWD Pearl,
86 XT Lt Blue,
85 XT AWD/4x4 Turbo Space Blue
Old 12-10-2007, 03:05 PM
SubaSteevo's Avatar
No longer blue member
thanks!
david
Max PSI is exactly that, the maximum safe amount. You should NEVER fill a tire to the max as the air will expand as it heats.
I usually kept the tires around 36/32, I believe the factory specs are 33/28.
-Steve
01' MSM Lexus IS300
Old 12-10-2007, 03:16 PM
SVeXy96's Avatar
SVeXy96 SVeXy96 is offline
Sold my soul to Subaru
Close! Its 33/29 which is what I keep my tires at all the time
Old 12-10-2007, 04:55 PM
Crazypolo95 Crazypolo95 is offline
95pologreen
Send a message via AIM to Crazypolo95
i have the SPT ones of thise but in 235/45/17 with the PSi at front 36 back 34
thanks!
david
Old 12-10-2007, 05:51 PM
I'm totally with Steevo on this.
I keep mine on 35-31 or 36-32. Factory specs are too soft. It allows the car to wallow on the side-walls. Plus it makes the steering heavy for parking. Plus it wears the outsides of the tire tread.
Run 3 to 5 lbs harder than spec. No penalty, better mpg. No-brainer.
Old 12-10-2007, 06:58 PM
Wikedjuggalo's Avatar
Rebuilding
o.k so I might have gone 5 over, 38 in front, 33-34 in back gauge kinda sucked. Is that too high? I just inflated them and I can feel the difference in handling
Old 12-10-2007, 07:32 PM
porschekiller porschekiller is offline
Banned
Door Badge!
Old 12-10-2007, 07:39 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
I usually do 38f/34r on both my summer set of tires and winter set. The stock 33/29 felt underinflated to me.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 12-10-2007, 08:14 PM
Nevin's Avatar
Nevin Nevin is offline
I run 40 in the front and 38 in the rear. I work at a tire shop and we normally just put in whatever the tire says. You'll get the best mileage that way, and your tires will last longer if you keep the pressure higher. The less a tire flexes the more life you'll get out of it, and since most often a tire is rated to run at 44 psi, it's best to just use that. I normally just run a couple pounds lower to improve ride quality.
The tires I currently have on the car are Michelin Pilot Exalto 225/50R16. 40f/38r psi. seems to work very well. I thought the car rode smoothe before with my potenzas, but it feels like I'm riding on a cloud now!
Jesus is the remedy
2015 Expedition EL Ecoboost
Old 12-10-2007, 10:37 PM
subarufamily subarufamily is offline
36 in front hot ,33 in back hot, found rides smoother better mpg open road 31 mpg. all my cars are set higher than what door badge says
William
Old 12-11-2007, 02:44 AM
It might be a little high, but you can see a few people run higher pressures than the door badge.
Running 44 is too high for me, too far off standard. The possible downside is the centres of your tires may wear faster than the sides, and also you might not get good braking in extreme circumstances, so safety could be compromised.
Somewhere around 36-32 should be a good compromise.
Old 12-11-2007, 06:54 AM
Tim's Avatar
Tim Tim is offline
The other issue is that the ride may become bouncier.
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 12-11-2007, 07:05 AM
That's true as well Tim
Another issue with hard pressures is the suspension is getting more of a pounding if they are really hard. At closer to correct pressures there is bump absorbtion in the deflection of the tire. With very hard tires practically all the shock is transmitted to the dampers and the joints, with corresponding higher wear.
Old 12-11-2007, 04:04 PM
ssnsltd's Avatar
thanks Guys!
David
the Chick Magnet:
90 Yamaha V-Max
"U-sta-have"
88 XT6 AWD Pearl,
86 XT Lt Blue,
Old 12-12-2007, 06:08 PM
immortal_suby's Avatar
Thread Killah
I have to jump in here (as a tire building/unformity technician)
The worst thing you can do for your tires and your safety is run too little air pressure.
Most air pressure ratings on the door jam are low. Car manufacturers often under inflate to soften the ride. The SVX inflation recommendation on the door jam is low.
You will get better on road handling and increase the life of your tires by putting more air in them. Every rotation of the tire causes flexing of the belts as they enter and exit the contact patch. Flexing of the belts causes heat. Heat kills tires. More air will give you a stiffer tire that may ride a little harsher but it should last longer, handle better, and actually increase your mpg. The worst part of a tire for heat is the edges of the tread (where the summit belt edges are) This is the part that take's the most beating from underinflation. This is the area where belt separation will begin from too much heat (see firestone/explorer)
I usually am within 5-10 psi of the max cold inflation on all of my cars with the rear around 3-5psi lower than the front. I've never worn out the center tread before the sidewall doing this.
Pump 'em up hard, drive it, and then lower the rears a few psi at a time until the handling feels right.
Locker Link
2015 BRZ Limited 6MT
