Old 12-09-2007, 04:23 PM
mikeytown2 mikeytown2 is offline
Question Heater Coil Leaking
Passenger side is wet, windows fog up, smells like antifreeze, and i have to keep filling up the radiator with new fluid. I have a 92 SVX with 190,000 on it. I was checking the lower hose on the passenger side and it seems fine. My guess is the actual heater coil is busted.
I am looking for a how to for replacing the svx heater coil. I searched this forum, but couldn't find anything. If anyone has anything on where to start from, that would be greatly appreciated!
Thanks in advance!!!
Old 12-09-2007, 06:42 PM
When following the steps to remove the evaporator in the a/c how-to you will see how to remove the heater core.
http://www.subaru-svx.net/photos/files/How-To/14349.pdf
blk 92' LSL w/ average mods
Old 12-09-2007, 07:20 PM
Sweet thanks!
Code:
EVAPORATOR
         Removal
         1) Disconnect negative battery cable. Discharge A/C system
using approved refrigerant recovery/recycling equipment. Disconnect
low- and high-pressure hoses from evaporator.
         2) Remove glove box. Disconnect fan control amplifier
connector. See Fig. 8. Remove time control unit. Time control unit is
located above fan amplifier. Disconnect cooling unit drain hose.
Remove cooling unit bolts.
         3) Remove cooling unit. Remove refrigerant temperature and
evaporator sensors from cooling unit. Remove clamps holding cooling
unit upper and lower housings. Separate cooling unit housing. Remove
evaporator. See Fig. 8.
         Installation
         To install, reverse removal procedure. Evacuate and charge
A/C system. Check A/C system for proper operation.
         HEATER CORE
         Removal & Installation
         Remove heater hoses inside engine compartment. Drain heater
core, and cap heater core pipe. Remove cooling unit. See EVAPORATOR.
Remove evaporator. See Fig. 8. Remove heater core. To install, reverse
removal procedures.
Fig. 8: Exploded View Of Cooling Unit
http://www.subarupartsforyou.com/cp_...hp?partid=9476
Courtesy of Subaru of America, Inc.
Fig. 1: Locating A/C-Heater System Components
One question though... is there any way to do this without disconnecting the AC?
Old 12-09-2007, 07:24 PM
I haven't done it on a SVX, but I would venture to say that you would definitely have to evac the a/c system.
Old 12-09-2007, 07:27 PM
You could just bypass the heater core if you can stand the cold and don't want do fix it properly due to $, time or lack of tools.
Old 12-09-2007, 07:28 PM
nextse7en's Avatar
Graphic Artist
Heck, its not THAT bad a job.
I've got one to spare if you need it. PM if you'd like it.
-Patrick
Patrick
6Xk Miles.
[SIGPIC][/SIGPIC]
Old 12-09-2007, 08:16 PM
I am going to double check my diagnosis of the heater core because this looks like as much fun as when my flex plate broke. Thanks for the pdf, I'm going to recheck the lines and hope i just missed one that was leaking. If the core is bad, I'll do the quick bypass fix for now.
What about the stop leak radiator stuff? If i were to put the heater core in its own closed loop and pump the stop leak through it, would that work?
Thanks Patrick for the offer, I see your in the northwest! I'll PM you once I'm 100% sure (heater core out of my car).
Old 12-09-2007, 08:27 PM
I am not sure about the stop leak fix, but do believe that doing it like a closed loop is a good and bad idea. It's smart as it doesn't put that crap into the rest of the system; but bad in that I am under of the impression that heat is involved in the sealing process. It may depend on the product you are going to use as they all can't be the same and therefore all have different operating properties. I think YT has a favorite brand, so PM him about this. I prefer the GM Top End sealer tabs. I think NAPA sells them.
