Old 12-06-2007, 07:29 PM
Wikedjuggalo's Avatar
Rebuilding
Squealing with Heater/AC on
O.k just started, Freaking squealing loud when I turn on the AC or Heater, its kinda loud and annoying. It is blowing both hot and cold good. Any clues? Started when it got colder out.
Old 12-06-2007, 07:31 PM
loose and/or glazed belt
blk 92' LSL w/ average mods
Rebuilding
what is a glazed belt? ; ; how do I tell which it is.
Old 12-06-2007, 07:33 PM
redlightningsvx's Avatar
Collision Refinishing Tech
my old car did that and then some, it was my alternator i turn on a/c or heater (sqealllllllllllll) turn it off and it goes away hopfully its just a belt
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 12-06-2007, 07:41 PM
Rebuilding
How Do I tell ; ; ? Great to know options it could be ,but I appreciate the opinions
Old 12-06-2007, 07:45 PM
Glazed belt will look shinny in day time and is caused by heat or fluid contamination. Heat usually generated by slipping on a pulley due to lack of tension. So basically it's a loose belt or a loose belt. Small chance that there is a bad bearing making the noise, but it does happen. You could spray a silicone lube or belt dressing onto the belts while the motor is running to see if it is indeed the belt.
edited for fluid
Old 12-06-2007, 07:55 PM
Rebuilding
Originally Posted by YourConfused View Post
Glazed belt will look shinny in day time and is caused by heat. Heat usually generated by slipping on a pulley due to lack of tension. So basically it's a loose belt or a loose belt. Small chance that there is a bad bearing making the noise, but it does happen. You could spray a silicone lube or belt dressing onto the belts while the motor is running to see if it is indeed the belt.
o.k so basically good chance belt is loose? I do wanna mention one thing, It would do it when it was warmer out but only for a minute when first started up. It has gotten worse as it has gotten colder.
Old 12-06-2007, 07:59 PM
definatly sounds like my old car. do you have a subwoofer? it could be overworking the alternater thats how i killed it
Seth
Past subies:
Other toys:
Old 12-06-2007, 08:01 PM
Rebuilding
lol no, I did put a stereo in a while ago, it did it before hand though.
Old 12-06-2007, 08:04 PM
ok just open the hood and start the car, have someone listen for where the sound is coming from that will give you a better idea
Seth
Past subies:
Other toys:
Old 12-06-2007, 08:11 PM
Rebuilding
I did that myself, sounds like it is coming from the AC compressor thing ( I know my terminology is right on point) definatly coming from that area. I personally don't see how how it could be alt. But Cars are mystical creatures and I thank everyones help. I think loose belt sounds right but again I am young and have not had much experience with cars, let alone SVX's
Old 12-06-2007, 08:15 PM
your compressor my be shot then
Seth
Past subies:
Other toys:
Old 12-06-2007, 08:16 PM
Rebuilding
O.k, >.x not what I wanted to hear, but it is making cold air and also blowing it out nicely. I am not trying to argue with you or shoot down your help again thank you.
Old 12-06-2007, 08:34 PM
Well if you don't feel like spraying something on the belt then just take it off to see if the noise goes away as a first step in the diag process. Otherwise good luck with it all.
Old 12-06-2007, 08:36 PM
Dessertrunner's Avatar
I go for a stuffed belt old and lost its grip.
