Old 12-06-2007, 02:14 PM
It's Just Eric's Avatar
Missing in action
a gauge cluster question
And pretty easy one to I hope.
How do you get the needles off? Do you just yank them off or what? Id rather not break anything while I try this, so knowing is good
-Eric
R.I.P Cool Signature.
Old 12-06-2007, 02:36 PM
-Eric
The pointers are fitted onto a taper on the shaft and pull off. Pull or lever with two implements on the center hub and directly outwards so as not to bend the shaft. Be careful.
Before removal mark or note the position of the mechanism and pointer, so that you can refit as removed and do not upset the original calibration. You may find a small mark on the face, placed there for this purpose.
Old 12-06-2007, 02:59 PM
Missing in action
thanks trev, just gave tem a bit harder of tug and they popped right off
Old 12-11-2007, 05:55 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
A bit of a late post but if you use a small flat screwdriver, you can gently wedge it under the center and the needle assembly will pop straight up and off.
1995 Subaru Svx L / AWD
