Old 12-01-2007, 10:36 PM
racerx9146 racerx9146 is offline
Unhappy Ignitor Partial failure possible
My initial question is: Is it possible to have weak ignition module (ignitor)?
Now the background
Been fighting a issue with my 92 SVX powered Vanagon. I have read just about every troubleshooting case on this forum and tried many fixes with no avail so I thought i would throw myself on the mercy of the group and see if anyone can think of anything I have missed.
1992 SVX (approx 150K miles)
Symptoms
  • Problem has developed gradually over last 6 months
  • Upper RPM power seems poor but will rev out
  • Slow starting sometimes(4 or 5 cranks)
  • Stumbling at 1st start but problem seems to lessen when outside temperature is low (below 60 degrees F)
  • Performance is sluggish, like a 25% loss
  • occasional cutout under very high load (happened twice, only for a second)
  • Idles perfectly at 600 RPM but seem a little rougher like it should almost like a soft misfire.
  • Sometimes smells richs at start
  • Seems to run hotter than it used too
  • Engine does not rev as freely as it used too (in neutral)
Current troubleshooting performed
  1. No current or stored codes present
  2. Replaced both injector rails with used set, no change
  3. Replaced 1 bank of coils with used set, moved 1st set to other side, no change
  4. Tested coils with coil over plug tester, all report good
  5. Replaced TPS, no change
  6. Tested auxilary air valve, open when cold, closed when warm
  7. Tested for intake leaks
  8. Checked all Vacuum lines, replaced those under manifold less than 1 year ago
  9. Leakdown test - all cylinders report 20%
  10. Replaced ECU coolant temp sensor
  11. Both O2 sensors are new and Select Monitor shows them cycling (high to low)
  12. Tested fuel pressure regulator
  13. Replaced air filter, fuel filter, fuel pump
  14. Tested fuel pressure twice
  15. Replaced NGK irridium plugs with new
  16. Cats are flowing freely (not blocked)
  17. Throttle body was cleaned 1 year ago
  18. PCV is fairly new
Whats left?
  • Partially failed Ignitor, might explain why problems seem less apparant at cold ambient temps? Is this possible?
  • Cam angle sensor? Wouldnt this throw a code?
  • Slipped timing belt? Would it even run this good?
  • Iris system not working?
  • Crank sensors? Tach works fine!
  • EGR system, could it cause these problems?
Thanks for any help you can provide. I have the Stage 1 chip and the crush mod has been performed (did help with stumble) I love this engine when all is well!
John Daron
Old 12-02-2007, 12:21 PM
Now the background
Symptoms
Whats left?
John Daron
Greetings John,
Thank you for going to much trouble in setting out an exact statement regarding your SVX, including symptoms and areas covered to date. It is seldom that this sort of effort is recorded. It is apparent that you have approached the problem in a very logical way.
The igniter in effect comprises six solid state relays. The failure of a solid state switch is not usually intermittent and engine load should have no affect. It has not been reported here that the igniter is in any way a commonly faulty. However nothing can be taken for granted in this regard and one must depend on a logical approach.
(5) When the TPS was replaced, did you set it properly by measuring the voltage output at closed throttle? Refer the how too section, or my locker for details.
(6) Excellent that you have checked the AACV as few have done so.
You rightly have doubts in some areas due to no fault codes being recorded, However I am sure that you appreciate that the system is not infallible. As a result all sensors must remain suspect.
The outstanding item in your list is the air flow sensor (MAF). You report a possible rich mixture and improved running at low temperatures. Faulty sensing of the intake air flow could very well result in all the symptoms you describe.
I respect and admire you for providing your complete identity.
Sincerely, Trevor Sheffield.
Old 12-03-2007, 11:40 AM
Thanks for the help Trevor. I have a friend who lives about a hour away with a parts car. Seems like the next (cost effective) step is to visit him and try to swap some parts starting with the MAF sensor. I imagine thats not a cheap unit!
It also appears like the cam angle sensor has caused people "difficult to solve issues". That might be my next part to try after the MAF.
thanks John Daron
Old 02-15-2008, 02:20 PM
resolved
Old post but I wanted to let everyone know that replacing the MAF sensor fixed all my wierd problems. Thanks for the help.
John Daron
Old 02-15-2008, 02:51 PM
John Daron
Great news Daron,
It is very worthwhile when members report outcomes, as this adds valuable information the knowledge base.
We struck the jackpot. However after all your work eliminating the many possibles it was not hard to pick the Joker.
Cheers, Trevor.
Old 02-15-2008, 03:06 PM
I saw you had asked a question about the timing belt. Maybe it will help others who read this or maybe it will help you in the future. Yes, if the timing belt jumps a tooth or two on the passenger side pulley, it will run very strangely and no error codes will be reported. Glad to hear it was simply a faulty MAF sensor. Good luck
Old 02-15-2008, 03:21 PM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Clear?
Did I understand this correctly--it was an SVX engine in a Vanagon?
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 02-15-2008, 04:03 PM
Yes Lee, it is a fairly common conversion these days. Smallcar has a ton of stuff for a conversion like this. Thats where I get my header flanges for the engine.
Old 02-16-2008, 07:43 AM
lhopp77's Avatar
I Know
I know because several very fixable SVXi have been parted because of the conversion. The vans will make more money than a repaired SVX, but that still doesn't justify the cannibalism for an SVX lover. It actually makes me sort of sick.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 02-16-2008, 07:51 AM
Lee
I understand your anger and frustration. But you cannot convince everyone, I learned that quickly
