Old 11-30-2007, 09:37 PM
jeffast jeffast is offline
I kill more trannies then god
how to trouble shoot my power steering
ok, my powersteering light is on, and i have no power steering. how can i pull the codes?
also my trouble shooting ended with checking for fluid in the system, there was plenty, and no leaks that i could see.
1991 xt6 eg33?
1993 gc track car
Old 12-01-2007, 06:04 AM
Have you checked what is available in the How-To section?
Here?
There is only a diagnosis system for electronically controlled power steering. If your car has the engine speed type, it can't be read by the OBD1
If yours HAS Electronic steering, here's how to go about checking it:
Before checking codes:
Ensure battery voltage is OK.
Check fuses 8 and 15 in Fuseboard, and 25 in Main board
Then, if those are OK:
Go to the plugs in the footwell. You will be plugging the diagnostic connectors into plug B36, the one with ten terminals.
The terminals read as follows, looking into the plug with the retainer clicker top centre:
1,2,3,4
5,6,7,8,9,10.
To read Memory:
Turn ignition OFF
Connect male terminal to terminal 6
Start engine
Read code/s
Turn ignition OFF
Disconnect the male connector.
To read Check aka D-Test:
Turn ignition OFF
Connect male terminal to terminal 5
Start engine
Drive at least 10 metres
Read code/s
Turn ignition OFF
Disconnect male connector.
To Clear Memory:
Turn ignition OFF
Connect both male terminals to 5 & 6
Start engine
Turn ignition OFF
Disconnect both male terminals.
Repeat read memory test to ensure memory is cleared.
To read codes:
Codes are shown by the blinking of the Power Steering light.
Long light is 10, short light is units.
e.g. 15 would be long light for 1.2 seconds, followed by 5 short lights of 0.3 seconds.
Power Steering Codes [Electronic only!] are as follows:
VF Light remains ON Faulty Source Voltage
WF Light remains OFF Faulty check mode terminal, lamp, wiring etc
1 One short blink Shorted solenoid system circuit
2 Two short blinks Open in Solenoid system circuit
3 Three short blinks Faulty vehicle sensor 2 system
4 Four short blinks Faulty back-up power supply
5 Five short blinks Faulty engine speed signal system [incl EGI ECU]
Normal is 0.6 second blinks and gaps.
OK, so run those checks and see if it tells a story.
Old 12-01-2007, 06:19 AM
rvnmaniac rvnmaniac is offline
Formerly known as henryrace@hotma
Here?
1,2,3,4
5,6,7,8,9,10.
To read Memory:
Turn ignition OFF
Start engine
Read code/s
Turn ignition OFF
Turn ignition OFF
Start engine
Read code/s
Turn ignition OFF
To Clear Memory:
Turn ignition OFF
Start engine
Turn ignition OFF
To read codes:
That's explained excellently..............
HENRY
92 SVX Claret(No More)
12 Camaro ZL1
89 Yamaha FJ1200
07 Yamaha FJR1300
"GO RAVENS"
Old 12-01-2007, 08:56 AM
Thanks for the compliment Henry.
We probably need to write it up with a couple of pics for the How-To section.
Old 12-01-2007, 01:02 PM
cool thanks, i didn't see the write up in the how to section.
how do i tell if my car has the electronic power steering i believe mine does but i'm not sure
1991 xt6 eg33?
1993 gc track car
Old 12-01-2007, 01:12 PM
crazyhorse's Avatar
242,000 mi on oem trans
IIRC the LS didn't have it, but the LS-L did. Not sure about the later L, or LSi though.
"42"
Current Stable By Age:
Old 12-01-2007, 01:20 PM
ok well min e is an lsl so i guess i do, off to go to work then joy fully trouble shoot
1991 xt6 eg33?
1993 gc track car
Old 12-01-2007, 02:14 PM
According to the Joe Spitz page the '92 LS had the engine speed steering, but the Tour package included the more expensive electronic vehicle speed steering system.
So it looks like you are good to go!
Old 12-01-2007, 09:11 PM
ait, i thought in 92 the lsl was the same as the touring package?
as far as options go i have yet to find one that mine doesn't have.
is there an easy way to tell?
1991 xt6 eg33?
1993 gc track car
Old 12-02-2007, 01:07 AM
Hondasucks's Avatar
Subaru Technician
LS-L = Touring (Leather, power driver's seat, sunroof, etc) LS = cloth, no power seat, no sunroof)
1986 VW Jetta
Old 01-31-2008, 01:18 AM
ok, so i got two codes one and two, any chance this is just unplugged i didn't have time to get under the car ,and it was snowing so i didn't investigate further
1991 xt6 eg33?
1993 gc track car
