Old 12-01-2007, 11:53 AM
tiv0's Avatar
tiv0 tiv0 is offline
svxless
well, after talking to my stepdad about all of this (he's a pretty knowledgeable when it comes to subarus)
he's recommending that i maybe add a little ATF so that the level is a little higher than LOW
and then just leave it alone and see how it all works for me
then if i encounter any more problems, we can start dealing with it again
Trevor
Avondale, AZ
1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13
1992 LS-L Claret 178k totaled 10/26/09
1987 BMW 325is
60% of the time it works, every time
Old 12-01-2007, 12:06 PM
crazyhorse's Avatar
242,000 mi on oem trans
Sounds like your step-dad is right on target
"42"
Current Stable By Age:
Old 12-15-2008, 04:54 PM
tiv0's Avatar
svxless
Re: revving in D
so im starting up this year-old thread to announce that im once again having the same problem
only this time its revving in 3rd (gear selector in 3)
my solution to this last year was driving all the time in "3" instead of "D" which I usually did
but now im kinda back at square one
my experience with it today was around 3 pm when i left school
the car had been running for a good 5-10 min, waiting to get out of the parking lot
but once i got out onto the road and came to my first red light, i push the accelerator when the light turns green and the car started to move VERY slowly, maybe 5 mph tops
in panic mode, because of the oncoming cars behind me i kept hitting the gas but nothing would happen.
thinking maybe another gear would change things i slipped it into 1st and it took off normally
i really cannot speculate as to what the problem might be?
bad tranny?
Trevor
Avondale, AZ
1987 BMW 325is
Old 12-15-2008, 05:34 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Re: revving in D
Sounds like you might be running in safe mode. Any power light flashing on start up for a transmission code?
Gene
Gene and Ben
Old 12-15-2008, 06:58 PM
tiv0's Avatar
svxless
Re: revving in D
no power light flashing on start up
i do have power mode constantly on, but i see this as having no effect on anything related here (i did the power mode mod early fall and havent experienced any problems)
this has just started again now that the subfreezing temps are here
Trevor
Avondale, AZ
1987 BMW 325is
Old 12-15-2008, 07:53 PM
michael's Avatar
michael michael is offline
What Potholes ???
Re: revving in D
Is your svx equipped with an external trans fluid filter?
Do you have an external cooler?
Do you have the original 92 style radiator?
Have you ever cleaned your TPS? (throttle position sensor)
Old 12-15-2008, 08:25 PM
tiv0's Avatar
svxless
Re: revving in D
no to all except the 92 style radiator
Trevor
Avondale, AZ
1987 BMW 325is
Old 12-15-2008, 08:43 PM
Re: revving in D
Does it rev up and go nowhere or do you just hit the gas with little or no revving and it seems to just crawl?
I ask because if it does not rev up but instead just seems to crawl, that is characteristic of it in safe mode. If it just free revs then it is more than likely internals in the transmission.
Oh i see it took off when put into "1". Try putting it into "2" and see if it drives normally and shifts normally from 1st to 2nd gear. Make sure you turn your power mode off when you do this as it will be easier to diagnose. If it does in fact shift normally into 2nd gear, try putting it into "3" at say 30-35 mph, If it then just revs up at that point, then it is probably the high clutch and you need a rebuild.
Old 12-15-2008, 09:14 PM
tiv0's Avatar
svxless
Re: revving in D
typically it just revs up and goes nowhere
it was only today that the car seemed to move a bit when i hit the gas (when i was having the issue)
i will try it in 2nd
but i think why im most confused is because it will rev in 3rd, or D, (and i never know when to expect it, except when its a really cold morning and i come to a complete stop)
so ill put it in a lower gear and it will almost always move right away and then i can immediately shift back into 3rd or D and wont experience the problem again.
im at a loss as to why it does it only once, upon my first stop, and then not do it again
Trevor
Avondale, AZ
1987 BMW 325is
Old 12-15-2008, 09:45 PM
Re: revving in D
What is going on w/ the indicator light on the dash when this happens??
BTW the SVX does not have "safe mode" for the transmission
in the winter the trans "cooler" is actually a trans warmer. The single pass rad cooler is meant to act as a thermostat for the transmission to keep it at operating temperature. What kind of outside temps are you seeing??
Old 12-15-2008, 10:16 PM
tiv0's Avatar
svxless
Re: revving in D
there are no dash lights on; at least none that shouldnt be on
this morning the svx read an outside temp of -6 F
but on average (for now at least) its right around 0 degrees F
Trevor
Avondale, AZ
1987 BMW 325is
Old 12-16-2008, 05:27 AM
michael's Avatar
What Potholes ???
Re: revving in D
Mabey Tom can answer this. What would happen if his passage through the radiator was partially clogged? I think a combinatiom of that and the really cold thick atf might be causing this.
Old 12-16-2008, 06:13 AM
Re: revving in D
I am sorry, I was not clear. I was asking about the lights that indicate what gear you are in.
It would effect the overall performance of the trans and would have likely destroyed it by now
Old 12-16-2008, 09:48 PM
tiv0's Avatar
svxless
Re: revving in D
the light shows the correct gear that the selector is in
Trevor
Avondale, AZ
1987 BMW 325is
Old 12-17-2008, 05:20 AM
michael's Avatar
What Potholes ???
Re: revving in D
Did you try letting it get to operating temp? You may want to invest in a remote car starter, at temps that low i woul never drive a cold car. Mabey i'm supersticious but i think it can lead to other problems too. Blown HGs, engine wear etc...
