Old 11-26-2007, 02:36 PM
BenSVX BenSVX is offline
HELP - Supposed to buy this Friday...
Hello all,
I am supposed to be buying my second SVX this Friday. It has everything done to it I don't have the time or $ to do to mine (5 spd, PWR rad, etc. etc. on down through to the Stebro)...
The seller went to safety it at the dealer today and came back with these observations...
"Everything during certification inspection was ok except that;
front engine is leaking a bit of oil, power steering is only pumping
at half power - (as you may have noticed during test drive) needs
further analysis, hood struts have to be replaced for certification."
1) Am I getting myself into something I can't handle - i.e. I have little money, time, or mechanical expertise..
2) Should I demand these be done prior to the sale at his expense (doubtful that he would...)
3) Buy it anyway, swap with my current pump (affecting my hopeful near future sale), get struts from Canadian Tire (I remember a thread with $30 "options" and hope the leak is not a big deal....
Thanks for your responses...
Ben
92 Graphite LS-L Touring (136k miles) #4143
5 speed, ACT clutch, Sparco R-Speed shortshifter, Ecutune v1, Stebro exhaust, PWR rad, 18" Motegi Racing FF15 wheels wrapped in Falken Azenis, Alpine 9833 MP3/CD with Alpine 3ways in front, MSW G-lateral drop springs, ss braided brake lines, d/s rotors, 9005 headlight mod, Celcius mod
92 Ebony LS-L Touring (125k miles) #7328
smallcar shift kit, Panasonic MP3/CD, Remote starter with security
For Sale: http://www.subaru-svx.net/forum/show...370#post501370
92 Claret LS-L Touring (Sold - 1998)
The first car I ever drove.
Old 11-26-2007, 03:03 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
the steering pump is the only thing I'd have looked at more. you want to make sure it's the pump and not something with the rack itself.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 11-26-2007, 03:49 PM
You need properly working hood struts to pass certification?? Would a chopped broomstick meet technical specs?
With the engine running have someone turn the steering wheel from side to side while you watch the steering pump pulley. If you notice "skipping" in the pulley, then either the belt needs tightened or the crank pulley is slipping.
Old 11-26-2007, 04:04 PM
Thanks for the replies so far...
I unfortunately live 4 hours away from the seller so I do not have access to the car to check the P/S myself. I have been planning for a few weeks now to drive there with a friend when all safety, etc. has been done, transfer title and drive it back. These new revelations have put a kink in that plan.
Questions:
1) Could it just be an old o-ring in the P/S? Or would Subaru have figured that out on their own?
2) I've heard that a "small oil leak" is not uncommon with these cars and are often nothing to worry about - how can I verify this one is "nothing" pre-purchase?
Answers:
1) Yes - hood struts are apparently necessary to safety the car in Ontario. If not a broomstick, you'd at least think a hockey stick would fly up here...
Thanks again
Ben
Old 11-26-2007, 04:10 PM
I've heard of dealers giving a preliminary report that the steering rack or pump will need replaced. Many of these have been fixed by a belt or replacing the o-ring.
Mild front leaks are common on 1 year old Subaru's. $200 worth of parts and a good afternoon can fix them and get you a new water pump and timing belt.
hehehe... a hockey stick... why didn't I think of that...
Old 11-26-2007, 07:53 PM
Yes, it could be the O-Ring. Subaru may not have figured that out. Many members have had the shop tell them that they needed a new pump when an O-Ring fixed their problems.
Old 11-26-2007, 09:38 PM
Thanks Earl and Dave,
I just got off the phone with the seller and suggested he take the SVX back to the dealer to confirm what is wrong with the P/S before I make the trek and spend the $.
He was reluctant and said he had driven it fine for the last 1.5 years with the slight pull on the steering and that another shop told him it was merely a pinched line...he's going to call me back - I offered to pay 1/2 the dealer labour to figure it out.
Could it just be a pinched line? Doesn't seem like Subaru would make a fuss about safetying a car if that's all it was...
Anything else you guys think of would be greatly appreciated.
Cheers,
Ben
Ben
Old 11-27-2007, 12:52 AM
kwren's Avatar
kwren kwren is offline
another shop told him it was merely a pinched line...???
Couldn't be the end of the world? Everyone of us svx men could replace a pinched line, and most of our wives and daughters could as well... with a little coaching. Where did all the craftsmen in the shops go that used to actually repair things?
Old 11-27-2007, 01:04 AM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
You're buying a 10-15 year old used car, even worse, an svx. If you don't have time and money for fix-its buy a newer Honda or something.
Brian
