Old 11-22-2007, 08:23 PM
Evil One Evil One is offline
Pinto Boosting Freak
Send a message via AIM to Evil One Send a message via MSN to Evil One Send a message via Yahoo to Evil One
Interesting CEL issue...
I had a hot start problem on SVXAPEALs 5MT 92, so I did the added start relay.
Works beautifully... 5+ hours of driving today and started great every time.
HOWEVER...
I can pull up to a stop light and push in the clutch and have the check engine light come on.
I will be sitting there with the clutch in and the rpms will drop slightly... then idle will pick up to around 1100.. and then back to normal... and the CEL pops on.
As soon as I release the clutch... in gear or in neutral, it goes out.
It isnt causing a problem... just a curious issue to have.
Jim
1992 Dark Teal LS-L with 4.44 swap. NC Plate "EVIL I" *Dont Fear the GEAR*
1977 Ford Pinto baby blue with 79,000 miles
Old 11-22-2007, 08:25 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Jim,
Have you tried to pull codes from the ECU to see if it's actually storing one?
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 11-22-2007, 08:27 PM
Not yet, today is the first day its happened... and we were out visiting family.
Will check tomorrow.
If I were a betting man, I would bet that it isnt.
Jim
Old 11-22-2007, 08:33 PM
SVXRide's Avatar
or you could bet on an O2 sensor on its way out
-Bill
Old 11-22-2007, 08:34 PM
I would rather bet on it being nothing
Jim
Old 11-22-2007, 08:42 PM
Do you have a clutch switch?
Old 11-22-2007, 08:48 PM
Yea, push in the clutch and you hear a relay clicking under the pass side of the dash.
Jim
Old 11-22-2007, 08:52 PM
I don't know how this has been connected, but surely here lies the source of your trouble.
Old 11-22-2007, 08:53 PM
Yea, my thoughts also.
CEL will be on, and as you ease the clutch out you hear the click at the same time the light goes out.
Jim
Old 11-22-2007, 08:55 PM
Jim
You will have to check with whoever did the installation.
P.S. Did this all start only after you installed the start relay
Old 11-22-2007, 09:03 PM
Yes, I installed the relay last night... and noticed it on the drive to NY today.
Jim
Old 11-22-2007, 09:07 PM
Jim
Exactly how did you install and connect the relay? What wiring did you alter?
Old 11-22-2007, 09:10 PM
Instructions in this thread. http://www.subaru-svx.net/forum/show...t=25362&page=2
Last post mentions rough running, CEL, and stalling.
He had it happen in neutral, I have my CEL with the clutch in... which should be activating the NSS.
Looks like related issues.
Jim
Old 11-22-2007, 10:06 PM
Jim
Please read the entire thread and understand the complications and problems involved. In particular note the comments by Beav concerning what is a make do fix.
http://www.subaru-svx.net/forum/showthread.php?t=25362
There appears to be variations in the starting system circuitry, dependent on whether or not a security system is installed. The ignition switch, a starter interrupt relay and the inhibitor switch can be involved, as well as all the associated wiring and connections.
As I have pointed out in another thread and have been ridiculed accordingly, fitting a relay has not fixed the original fault.
http://www.subaru-svx.net/forum/show...868#post509868
This fault has caused a drop in the voltage available to the starter solenoid. The fault could involve either resistance or a partial short circuit. The inhibitor switch would appear to be very suspect.
Until someone locates and identifies the fault, I regret that I have no more to offer on the subject.
P.S. Sorry you may have to copy and paste to browser.
