Old 11-11-2007, 06:21 PM
Michael Blue's Avatar
Michael Blue Michael Blue is offline
Sold. :'-(
4.11 Swap issues...
Hey there, me again.
Someone already posted a "last chance for my SVX" thread, so I won't steal his title, but this cat is plumb out of lives.
OK, so I had a 4.44 auto swap done this year (yeah the title's wrong) and I noticed it was leaking red fluid on my garage floor - assumed it was trans fluid so I bought some fluid and a funnel and waited a bit to check the level. This last week it started misbehaving (not wanting to shift from low gears) so tonight I pulled her inside, washed her all up and set about checking the trans fluid.
OK, this is the dipstick low by the firewall on the driver's side, right? Because it reads just over HOT full when COLD.
-pause for effect-
Yeah...So I'm thinking I'm pretty screwed here. Any suggestions at all that don't involve crushers?
Please help...
Thanks!
'92 Pearl White LS-L Touring SOLD
4.44 Swap, trans cooler, trans filter, trans temp gauge
Color-matched rear body and spoiler, X-drilled and slotted rotors, Axis pads, s/s lines
Raxles front axles
Old 11-11-2007, 09:27 PM
94SubieSVX's Avatar
OOC for a while
Did you put too much tranny fluid in it? I guess that might effect it.
bLAh
Old 11-11-2007, 10:56 PM
jeffast jeffast is offline
I kill more trannies then god
I WOULD REMOVE THE EXCESS TRANSMISSION FLUID.
i have heard that you can damage the transmission from over filling drain soem fluid and go from there
1991 xt6 eg33?
1993 gc track car
Old 11-11-2007, 11:07 PM
redlightningsvx's Avatar
Collision Refinishing Tech
IMEDIATLY remove some tranny fluid as the others have said. the red fluid could be either power steering or tranny fluid check both of these and all hoses connecting to them
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 11-12-2007, 04:07 PM
Sold. :'-(
I haven't touched the fluid since the swap was done earlier this year, Jason "BudFreak" did the swap and is who filled the trans. I will try to siphon some out.
That said; could being too full cause this problem, and why would it only show up now? Would colder weather cause this issue to be more pronounced?
Thanks!
Raxles front axles
Old 11-12-2007, 04:20 PM
Just to check;
Was the car level?
Did you cycle through all the gears?
Was it running?
Try it again after driving for 10-15 minutes to warm the fluid.
Old 11-12-2007, 11:47 PM
Sold. :'-(
Originally Posted by Hocrest View Post
Was the car level?
As close as it can be without checking with a level.
Please elaborate.
Was it running?
It has been driven over 1,000 miles since the swap, but as stated, was cold when the level was checked.
Will do.
Raxles front axles
Old 11-13-2007, 05:04 AM
Originally Posted by Michael Blue View Post
Please elaborate.
Before checking, with your foot on the brake move the selector through all the gears, pausing for about a second in each one. Then return it to Park and check the fluid while the engine is still running.
Old 11-13-2007, 04:31 PM
Sold. :'-(
I'll try that tomorrow.
Also, today I noticed that it doesn't seem to want to disengage the drive when you're on the brakes - like you're fighting the car when braking at slow speeds.
I'd guess this was part of the "performance modifications" done during the swap (never got a complete list of what all was done unfortunately) but I don't know for sure.
Could this be relevant?
Thanks!
Raxles front axles
Old 11-14-2007, 05:47 AM
Sold. :'-(
Just wanted to note; this morning, barely 50*F and rather humid, the car ran the best it ever has since the day I bought it. Could be the MAF TomsSVX sent me, could be the weather, could be any combination of things. I won't be able to drive it in normal conditions until Thursday at the earliest - more then.
Raxles front axles
