Old 06-30-2009, 09:10 AM
ninefourteener's Avatar
ninefourteener ninefourteener is offline
ABS issue
The other issue I'm having is with the brakes. It doesn't do it "all" the time... but it does it often.
When I'm coming to a stop in normal driving...... just a split second before complete stop (1mph or under).... the ABS activates and the brake pedal start pulsing. It's irritating..... but the major issue is that when you "think" you're about to stop..... the ABS surges, and I end up stopping 2-3 feet later than what I intended. By the way..... no ABS light on the dash when this happens.
Additionally..... occasionally..... the ABS light DOES come on during normal driving. Ironically, the problem listed above STOPS happening when the ABS light comes on.
When I shut the car off...... the ABS light does not come back on when I restart..... at least not immediately... may take hours before it comes back on..... and then I have to deal with the ABS activating inappropriately.
It's like the problem occurs when the car is supposedly running correct... and when the warning light comes on.... then the car runs properly????
What's my problem??????
--Matt
1978 Subaru Brat, Gold+rust, project
2006 Subaru WRX, CGM, Cobb stg 3, VF39
2007 Subaru B9Tribeca 7-pass ltd, PSM
1994 Subaru SVX LSi, Bourdeaux
Co-Founder / Site Admin: www.slcsubaru.com
Old 06-30-2009, 09:28 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Re: ABS issue
check the code under the passenger seat from the control unit.
The how-to is in www.svx-iw.com
1995 Subaru Svx L / AWD
Old 06-30-2009, 12:33 PM
Re: ABS issue
Forgive me for my ignorance.... but my only experience with reading "codes" is on my Cobb Accessport with my 2006 WRX.
Correct me if I'm wrong..... but don't you have to be getting some kind of warning light before the ECU tells you that there is something wrong?
The problem..... is that the "problem" happens when there are NO warning lights. When the ABS light does come one... then the problem stops.
--Matt
Old 07-01-2009, 09:36 AM
msvx95's Avatar
It's just a phase
Re: ABS issue
To me it sounds like the sensors are dirty or corroded...my chevy did that and they were corroded inside the wheel hub. My truck would kick in the abs and pedal would pulsate just before coming to a complete stop..no warning light..it was frustrating.
If I were you, I'd still look at the code the control unit is blinking, that's after you drive and follow the instructions for reading the ABS code OR take the wheel off and see if maybe the sensors are loose or dirty.
Old 07-01-2009, 11:10 AM
Re: ABS issue
The ABS has its own computer and error codes. It will show any stored codes even if the light has been off for some time.
Old 07-01-2009, 12:06 PM
Mike621 Mike621 is online now
Re: ABS issue
Get the ABS light to come on.
Stop the car, but don't shut it off.
Slide the RF seat forward and tilted.
Look for the tiny carpet flap on the inside edge of the right side seat rail.
Lift the flap to reveal the LED on the ABS unit.
Count the blinks.
Old 07-01-2009, 08:45 PM
Re: ABS issue
The code is likely for a left front wheel speed sensor. It was an intermittent issue when we still had the car. I check the tone ring and found it broken. I replaced the tone ring and hadn't dealt with it again. If you can pull the code, we will get another sensor out to you ASAP
Old 07-06-2009, 12:32 AM
Re: ABS issue
Thanks!!!
Been on vacation since I posted this... but I'll be home tomorrow and I'll check the code.
--Matt
Old 07-11-2009, 01:04 PM
Re: ABS issue
Well, we haven't driven it much.... but we did take a trip in it today, and after about an hour, we got the ABS light again.
(and strangely enough.... then the brakes work great)
I looked under the pass seat.... getting 5 blinks.
What does that mean?
--Matt
Old 07-11-2009, 02:24 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: ABS issue
Left front wheel speed sensor, and your brakes work when the light is on because the ABS computer deactivates the ABS function when it senses the problem.
Old 07-11-2009, 02:35 PM
Re: ABS issue
This is correct. I will order you a new sensor, just PM me the address it needs to be sent to
TOm
Old 07-11-2009, 09:12 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: ABS issue
Originally Posted by TomsSVX View Post
This is correct.
SCORE!!
Old 07-12-2009, 12:01 AM
Re: ABS issue
TOm
Thanks Tom.... PM on the way
Anyone have a link for a tutorial on how to do one of those?
--Matt
Old 07-12-2009, 12:17 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: ABS issue
Its pretty straightforward, if you havent downloaded it yet, get the service manual, the link is in my signature. You will find lots of handy info, flow charts, and step by step guides there. Its says 1992 but it applies to all years for the most part.
