View Poll Results: Does Your Car Pull to One Side? | |||
Pulls to the Left | 4 | 12.12% | |
Stays Straight | 21 | 63.64% | |
Pulls to the Right | 8 | 24.24% | |
Voters: 33. You may not vote on this poll |
Thread Tools | Display Modes |
Through a full four-wheel alignment and two new sets of tires, my car has always pulled strongly to the right. Anyone else have this problem?
-adam |
Pull
Just curious....do you have aftermarket wheels?
Don
Cats: Clio, Inky, Sheba, Sparky, Rocky, Cali, Scooter 3 cars: 02 SVT Focus, 2012 Versa...2015 Fiat 500 currently SVX-less 1 wife ("She, who must be obeyed..") "One advantage of being disorderly is that one is constantly making exciting discoveries" |
Mine stays straight with the stockers, and pulls right with the 17's.
Mike |
Re: Pull
-a |
FMC alignment rack has wrong specs
My Dad noticed after an alignment, that the stored spec's on FMC alignment racks is wrong for the SVX. He wrote a letter to the right folks. (He used to work for FMC).
mine pulled to right even with stocks. at the shop i set the alignment twice on my hunter machine still cant get the drift out
white leathers, h.i.d, ecutune S/C stage 4, 14 inch 2piece rotors big brake kit., , msd ignition, c/f dash kit, front spoiler,carbon fiber jdm rearc wing,19 inch rims, nos, , aem fuel regulater, koni-gc package, ported cylinder heads, supercharger cams,solid buck and shims,wrx sti intake valve and exhaust valves,& valve springs, gas analizer,water injection, exhaust temp gauge, idiglo gauges, shift kit, , remote start, all automatic windows,2.5 inch true dual exhaust system with crossover, and 2 borla stainless steal muffler,air filter velocity air stack 3inch to 6 for air filtre, group n mounts, momo steering wheel, dyno will happan soon |
Mine pulls to the right whe the road slants to the right and pulls to the left when the road slants to the left. What is it with the SVX being so damn sensitive to the angle of the road? I've never experienced this in any other car.
Out for good. |
You might get the impression that the car is fighting you, even just a little, because the SVX has pretty heavy steering at speed.
The reason this happens is because of your WIDE tires. If you drive a stock civic with it's tiny tires, it won't pull much... if you drive a vette or an SVX, it'll pull wherever the road leans.
If you drive that same civic with wider tires, it'll pull more. - Rob |
Troy 1992 SVX LSL "Serenity" 250,000 miles! I don't care, I'm still free, You can't take the sky from me... |
If you run lower profile tires, or have wider wheels, it'll pull more (to whichevery directionthe road is slanting). - Rob |
Pearl '92 LS-L 179K (Historic 1st 5-speed SVX) Mods: 5-speed, 4.11's, Group-N motor mounts, dual Magnaflows, cone air filter, Kenwood MP-228 CD/Receiver, white-faced gauges, '97 grill, custom window tinting. Ebony Mica '92 LS 80K Oct 2002 - Dec 2004: Victim of theft. She served me well. You can tell the lack of craftsmanship by the wrinkles in the duct tape. Last edited by CigarJohnny; 03-24-2003 at 10:30 AM. |
Here:
dangit. I can't get the link to work. Anyway, go here: http://www.neons.org/faq/ then go to 3.6.11 It talks about 'wandering'. Last edited by Chicane; 03-24-2003 at 10:33 AM. |
"Lastly, big rims with low-profile tires tend to wander, rather than track straight, as they are influenced by waves and bumps in the road surface". Note the key words..."big rims". Once you understand the physics behind it you will understand that it is the "big rims", not necessarily the corresponding wider tires that usually go with them, that cause the drifting situation, Rob. Those bigger rims, along with their wider offset are the cause. Remember that most of the Neon folks are going from 185/75/14 (or whatever) tires to 205/50/16 (or whatever) and there is a substantial increase in width (both rim and tire). When most SVX owners upgrade from the stock 225/50/16 they go to a 225/45/17 which has no change in tire width. If they notice an increase in wandering it is more likely due to a difference in wheel offset compared to the factory rims. Think about it and it will make sense to you
Pearl '92 LS-L 179K (Historic 1st 5-speed SVX) Mods: 5-speed, 4.11's, Group-N motor mounts, dual Magnaflows, cone air filter, Kenwood MP-228 CD/Receiver, white-faced gauges, '97 grill, custom window tinting. Ebony Mica '92 LS 80K Oct 2002 - Dec 2004: Victim of theft. She served me well. You can tell the lack of craftsmanship by the wrinkles in the duct tape. |
Steve '95 Polo Green SVX L AWD, 188K - "Kermit" (Gone, but not forgotten) '02 Outback LLBean, 56K '02 Black Sapphire Volvo V40, 133K - "Shadowfax" '06 Triumph Tiger, 19K '99 Suzuki DR350SE, 8.5K - "Geezer Killer" <*}}}}>< ~ ~ ~ ~ ~ ~ ~ ><{{{{*> |
