window won't go down
Can anyone tell me ahead of time before I take the door apart to get to the window what would cause my window to not go down, but I'm still hearing the motor working. I hear it going up and down, but the window won't move, so I'm not sure what broke. Is there a cable inside?
Re: window won't go down
Most likely it's the plastic piece that traps the bead on the cable. It's on the movable carriage that is attached to the window itself. You'll have to remove the door panel; force the window down far enough to expose the carriage; R&R the plastic clip around the bead on the cable, and reassemble.
What you're hearing is the cable traveling around without being linked to the window. Glenn
"The only thing necessary for the triumph of evil is for good men to do nothing" Aaron Burke 1993 25th Anniversary Edition #63 of 301. R.I.P. Rojo 7/24/2008 She saved my life! 1997 Ebony Mica Pearl LSI. BLACKBERRY 1998 5-Spd Legacy GT Wagon in Glacier White: NUBURU 2005 Cadillac STS in Sandstorm Metallic: STORMY Veteran and farthest traveler of 1st SoCal2MuseumsMeet2010. http://www.subaru-svx.net/photos/user.php?RojoRocket |
I took pictures of a broken plastic piece that I found in the bottom of the door.
The window cable goes up and down, but the cable nut obviously needs something to pull the window down. Is this piece the sleeve lock regulator 61246 (subaruparts.com)? I don't know how it mounts inside the door. Can someone tell me how to fix this? Or do I need a new regulator or something? |
Thats the thing. Motor the join between the two ends of the cable to about the middle of the door. That goes into the cavity on the plastic thing that broke. Once thats on the cable you can pull the window down and slide in the plastic clip into the metal bracket on the window. Be careful as right now the only thing holding the window up is a hell of alot of weather stripping.
I guess I can't figure out how that plastic piece looks when it's in the correct position...Can I just order that piece or do I need to order an assembly?...this piece I took a picture of looks like it's broken on the one end.
Are you saying pull the window down half way to see how the piece fits back on? |
you can order just the piece. it's called a sleeve lock regulator 62101PA081 Sleeve Lock Regulator $7.58
Matt Locker Link 2015 BRZ Limited 6MT 92 Ebony LS-L ECUtune Stage2av1, Z32 MAF, 370cc injectors, TomsSVX intake, BontragerWorks 22mm RSB #003, HID Hi and Lo beams, OT endlink and bushing mods, PWR Aluminum radiator, Harvey's QC shift kit, 2.5" flowmaster 80 exhaust, 17" Michelin Pilot Sport A/S, Poly sway bar bushings, Slotted Bradi rotors, AFBeefcake powdercoated calipers, 97 grill, and a huge set of air horns. 300,000 miles and counting 92 Ebony LS-L. ecutune stage1v4, motorsport 1pc pulley. Garage Queen - sold to Dad in upstate NY 155,000 miles 19 Subaru Ascent Premium - -Hers !. 89 DL 4x4 little red wagon - a.k.a. The immortal suby. 275k R.I.P. Last edited by immortal_suby; 10-26-2008 at 07:47 PM. |
you're welcome.
glad I could help
