Manual buttom? What is that?
SVX FAQ: "The only thing the manual button seems to do is to stop the transmission from automatically downshifting from 2nd to 1st gear. "
Can someone explain that for me? And is that the only function? What's the different between on and off manual mode as in the hwy cruising 60+mph? |
Re: Manual buttom? What is that?
The usage of the button is to hold the shift point. For example, You are at the traffic light. You want to manually hold on the first gear till you reach 6000 RPM instead of 3000 that the car normally shifts at. To accomplish that, you press the manual button -- manual light comes on -- shift car into 1. Press gas till you hit 6000 on the RPM. Then shift up into 2 and so on and so fourth. You can also downshift manually into 3rd -- I don't know why anyone would do that since it will screw up the tranny bad and the SVX already comes with weak trannies. Hope it helps... anyone else? Randy, am i correct? Lwin
Well, to paraphrase page 6-11 of the official '92 SVX Manual, "Manual" is not intended to turn the car into a stick shift, although some of you may have "creative" ways to do this. No, "Manual" is simply a way to lock the tranny into second & third gears, in order to deal with something called snow & ice. Nor does "Manual" have anything to do with the guy trimming your hedges. To those that HAVE found a way to make a "Huckmobile" out of the tranny, I believe "Manual" will apply to the labor required to scrape the eventual grenaded tranny-bits off the road.
Ron.
Good s**t happened. 69 was worth the wait. '92 stock semi-pristine ebony - 160K '96 Grand Caravan - 240K '01 Miata SE - 79K '07 Chrysler Pacifica - 60k - future money pit. |
I had a look at an SVX some time ago where the dealer (an imbecile by the way) talked arrant nonsense about the SVX and then on the test drive, proceeded to show me how it could be driven in manual form, "Like the Ferrari's mate".
As I got out of the car, I bade a quiet farewell to the transmission and wished the car luck in the future Jamsvx
1992 charcoal grey SVX: 27 August 2002 to 27 January 2004 - she will be missed Was back in Sydney for a while but not hot enough so now in Dubai! Has it been that long since I owned SVX-33H! |
My policy is to avoid all use of Manual mode, except for the occasions mentioned. If you're starting from a dead stop on a very slick road, then use it. Otherwise, keep your fingers off the button.
bill Green 95 SVX - Cleo Green 97 Outback - Maxine Red F-150 Extended Cab Long Bed - Big Boy Even the best monkey sometimes drops his banana. |
silver 92 SVX-"Hannah" -R.I.P. NOV. 1991-jAN. 17, 2003 red white and blue 2000 Suzuki TL1000-r-"Bethany" This grips me more than a muddy old river or reclining Buddha.(now running Metzlers! black 1987 Toyota MR2-"Helga" -Turbo conversion will now commence. 1996 Legacy Outback-"Gilda" white with brown trim |
BTW, where did you get your cow catcher? I almost had a need for one last night.
This is getting confusing. My understanding is this...
If the manual button is NOT pressed: Stick in 1: Car uses 1 only Stick in 2: Car uses 1 and 2 Stick in 3: Car uses 1, 2 and 3 Stick in D: Car uses 1, 2, 3 and D. However if the manual button IS pressed: Stick in 1: Car uses 1 only Stick in 2: Car uses 2 only Stick in 3: Car uses 2 and 3 Stick in D: Car uses 1, 2, 3 and D. Also, power mode does not come on when manual button is pressed. (If I have the power button pressed, the power light comes on. But then it goes out when I press the manual button and comes on again when I unpress it) Phil. Last edited by b3lha; 12-07-2001 at 06:25 PM. |
(Glad to hear you didn't ACTUALLY need it, and you're safe. Those cows are hell on sheet metal -- I know -- I totalled my 72 Gran Torino Sport after straightening out a curve on a rain-slick road and taking out two calves and momma while they were having dinner.)
b3lha,
You have the power mode button?? How come? Is it because you have a UK SVX? |
b3lha, how many units of SVX sold in UK? do you guys there have any like tranny probs & etc that we have?
say, if the 'button' is really faulty, how to track the problem & fix? PS:where're your scissors at?
As far as I know, all Alcyone's have a power mode button. UK SVX's on the other hand are the opposite. They are permanently in power mode unless you press the "economy mode" button. I don't think 249SVX's manual button is broken. He says: Quote:
Phil. Last edited by b3lha; 12-08-2001 at 08:44 AM. |
