Old 10-24-2007, 06:25 AM
svxual's Avatar
svxual svxual is offline
um just read this ??????
That'll mean that you can locate the engine intake to make the most of the free power often going to waste. You'll certainly avoid making some of the glaring errors that we occasionally see... like drawing air straight from the wheel arch - a low-pressure area in many cars!!!
aint ours like that??
http://autospeed.com/cms/A_1023/arti...popularArticle
Old 10-24-2007, 10:37 AM
black beast black beast is offline
Back Road Blazer
Send a message via AIM to black beast
I paid the $20 for a universal CAI duct at pep boys and routed it from the right (passenger side) fog light hole of my front bumper (keep in mind I have the "euro bumper") I like how the theorectical specs work, have not tested it yet. But in essence I am dumping higher pressure cold air into my filter.
-Chris
'94 ebony pearl, with orange "silicone" hoses, painted beauty cover, Tom's Intake, Dayles Cold air intake; with HKS mega suction foam air filter, 3in header back exhaust, STI ground wires, euro front fascia, euro front grill, reactive 17in wheels, Nitto Invo's, Drilled and slotted rotors, stainless break lines, Koni strut inserts, Drop springs, 5MT, shotshifter, Clutchmasters clutch, ACT prolite flywheel, EL Glow gauges, The ECUTune stage 2. To Do: Cams, port and polish, etc.
Old 10-24-2007, 10:45 AM
Back Road Blazer
see piture below for idea.
-Chris
Old 10-24-2007, 10:54 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
It does work...I've been running my custom ram air set up for ~2.5 years....(more pics and actual pressure readings in my locker)
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 10-27-2007, 02:15 PM
mbtoloczko's Avatar
sans SVX
Originally Posted by Myxalplyx View Post
Some finalized pics of the intake. Took off work today and picked up a small piece of piping to convert it to a cold-air setup. Was tempted to make it a ram-air but decided not to for hydrolocking sake. Filter is not as far down as it may appear. Utilized a Dale Motorsports cold air piping with an extra piece included. All in all, I'm satisfied. Here are some pics below.
Hole cut into bottom passenger-side to allow cold air in-->
Car is on jack stands if it looks like it is on an odd angle. Purchased the silicone piece and piping from Verocious Motorsports today (Connected to the dyno shop). Going back downstairs to button it all up.
The cold-air setup looks great! Did you dyno this as well?
Mychailo
Visit my locker
Old 10-27-2007, 02:26 PM
Nomake Wan's Avatar
Retired
http://www.subaru-svx.net/forum/showthread.php?t=41544
Old 05-03-2014, 09:20 PM
Myxalplyx's Avatar
XT6 is SVX's Daddy
Re: SVX ToMyx Intake Completed
~~Risen from 7yrs of zombie death
I came back here to research some info and to see if there have been any progress/fallbacks modifications wise. There is one thing I'd like to share with you guys that may have a cold-air intake setup. I tested something on my RAV4 and I wished I'd apply it to the SVX in search of that 14 second 1/4 mile.
Just before the maf sensor, all the piping that leads to the air filter I think should be enlarged. By how much? Every time the piping bends as it goes towards the air filter, try increasing the intake diameter by .5". So if the maf sensor is 2.5", as the piping leads away from it towards the air filter, increase it by .5". Once it hits another bend, increase it again by .5". I'll be testing this theory again once I get a 2015 Honda Fit (Don't ask..) but the results I got on my RAV4 was pretty good. http://www.rav4world.com/forums/99-4...dragstrip.html 1/4 mile times dropped slightly and trap speed increased. This was while changing the intake at the dragstrip more than once and testing again. J
I searched and searched the internet to see if anyone else tested this as I see no intake manufacturers do this on their cold air setup. They generally keep the intake diameter the same size but I just feel it's like sucking through a straw with the same diameter. It becomes more difficult the longer the straw is away from mouth, especially with turns. Increasing the diameter size increases the air velocity as it goes around the turns and frees up some pumping loss since the engine should not have to fight as hard sucking in air, with the intake diameter increasing the further way it is from the throttle body.
I was very passionate about this forum and Chike's car was a perfect platform to work off of. I can't see pouring my heart into another SVX ever again. Just a thought. Chow for now....
Kevin Thomas
***R.I.P***
