rear main seal leak?
Would a leaking rear main seal leak a lot of oil?
I just got my 5 speed swap done and now the motor is leak oil a lot of it. It only leaves a small spot on the floor, I starting it up and could not see any oil coming out, but a lot came out when driving. There is oil on the oil pan, motor cross member, and back. The car has 110,000. anyone have any info that would help me figure it out
2005 Legacy GT 2002 WRX VF22, Pinks, big TMIC and turbo back 128,*** miles My WRX's Cardomain Page |
my car leaks on all of that stuff but not a lot. Mine is leaking on the corners of the valve covers then dripping on everythiing else as you mentioned. try checking that to see if it answers your problem
Seth 94' Barcelona Red w/ Tricoat black 2-tone AWD Ls -Sold Mods:AWD conversion/4.44 swap by Budfreak, Custom red interior lights, Custom Satin black dash, Power mode switch, Cold air intake, Permecool tranny filter,Sony xplode 10" sub, Sony xplode 1000w amp, Blitz in-line driver, DDM Tuning 6000k HID's, New paint job/body work by me, 97' Grill, QC shift kit, 17'' MB Motoring rims, 15&20 min mod, front & rear urethane swaybar bushings, Custom fiberglass sub box, Custom red led a/c control unit, perrin lightweight crank pulley, Black wrinkle finish powdercoated intake manifold w/ clear hoses , 02' outback heated/power black leather seats Soon to come:Fiberglass hood, upholster ALL suede to black leather Past subies: 92' Pearl White/black top LS-L-SOLD 96' Legacy Outback-TOTALED 99' Legacy Outback Limited 30th anniversary edition-TOTALED 98' Forester L -Totaled Other toys: 99' Forester S -WRX brake upgrade, soon an 04 wrx motor swap 06' B9 Tribeca-Stock 1982' Yamaha xj650 Maxim Mods: work in progress |
Its not that. It lost like 3 qts in a 2 hour drive
If it is coating the engine oil pan, it is probably not the rear main. My first guess without seeing it would be one to three of the front seals. If you take off the side timing covers, you can check the cam seals.
OK, I saw this after my first post, check you oil filter. It may be loose or too tight.
<<Would a leaking rear main seal leak a lot of oil?>>
yes, but: only if someone put a new rear main and tapped it to far in (poor installation) or you put an engine into your car that has been sitting a while and the seal has dried out. other than that, my money is on the separator plate to the top right of the rear main seal. |
The filter does not look like its leaking. tomarrow I' ll take off the two end timing belt cover and look.
separator plate how is that sealed to the motor?
