View Poll Results: What would you do if you had 1/2 tread on 2 of your tires and the other ones are bad?
Get new tires (all 4) 24 92.31%
Put new ones on the front (2 new) - worn ones on back. 2 7.69%
Put new ones on the back (2 new) - worn ones on the front. 0 0%
Park that car. 0 0%
Voters: 26. You may not vote on this poll
Old 04-06-2003, 12:13 AM
Tires - What would you do?
My 94 SVX had the front end out of alignment and wore the front tires out on the side and side walls. It is now aligned and has been fixed.
Here is the question. The good tires have 5/8s tread out of 10/8s on new ones. For the record, they are Toyo Proxes (225/45 17).
Old 04-06-2003, 12:40 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Regardless of whether or not we're talking AWD cars, I always do four on my cars. I like having a matched set, they always seem to drive and ride nicer. Call it personal preference.
Old 04-06-2003, 12:59 AM
Definately get all 4. I mean...it's not like you don't have another car to drive in the meantime
Old 04-06-2003, 01:05 AM
Boone
That's my mantra. Keep the inflation differential and rotate at each o/c. Check the allignment and buy the best. B.
Old 04-06-2003, 01:54 AM
SVXdriver_007
I agree go with all four tires things are better that way.
Old 04-06-2003, 08:37 AM
Smile Gimme four, bro'
Earl,
I always go all four. If you keep the two best tyres off the old set, you can run with a full-sized spare, in fact two, you can have right and left.
Also, if you get uneven wear because of pothole-caused misalignment, you have the option of taking off two illegals, and putting on the two good ones you have kept, and the rolling radius will be close enough, taking wear into account.
This all assuming you opt for the same make/model/size tyre.
PS Buying a rim for a full-sized spare is worthwhile. If you go away on a long run, like 500-1000 miles [Reading?], Sod's Law might mean you could be driving high miles in the rain on the silly skinny thing. Just a thought. Anything approaching 300 miles, I load up full size.
Old 04-06-2003, 09:41 AM
I did this poll because of a lot of comments on not needing to get all 4 at once. My feeling was to get all 4 new tires at once, because of the difference in tread. I am going to do what I first thought. All 4 new ones. Thanks for the feedback.
Old 04-06-2003, 11:21 AM
STORMINORMAN STORMINORMAN is offline
Lightbulb OR...
...you could try and find two matching used tires with approximately the same amount of tread left.
I have found that there are quite a few performance tires available in less than a "set of four" quantity. I would guess new replacements in your size (V or Z rated) would be $125+ each (or more)?
A couple of decent used Toyo's @ $50 per would seem to me to be a bargain if you could get 10-15K out of them
BTW, Toyo makes a very good tire in 16" sizes, the Proxes TPT.
' 92 SVX @ 185K
' 91 420SEL @ 223K!
' 88 420SEL I. @ 178K (what a buy!)
' 87 F250 @ 180K
' 93 ZX-11D @ 29K
' 93 SC400 @ 93K
2001 Valkyrie Interstate @ 6.6K (Brynhild)
Y2K NightHawk 250 @ 1,500 miles
' 88 420SEL II. @ 208K
'85 F150 @ 135K
Old 04-06-2003, 06:44 PM
LarryIII LarryIII is offline
I had a set of Toyo T1-S tires in stock size. They were the grippiest street tires that I ever had. They were good in the rain and fair in the snow. I considered them summer tires. they were noisy and lasted about 25-30k miles.
Larry III & The Beautiful Naviguesser
'19 Tungsten Pearl Outback 3.6R Ltd...."AISHA"
'08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU"
'07 Gray Diamond Pearl Outback XT Ltd..."AH SO"
'05 White Pearl & Silver BAJA Turbo..."AH HA"
'97 Bordeaux Pearl SVX LSi..."SUBYDOO"
'94 White Pearl SVX LSi..."PEARLY"
'92 White Pearl SVX LSL w/touring pkg..."SVXY"
'92 Teal SVX LSL w/touring pkg..."ALCYONE"
'96 Polo Green LSi ... "MIDORI"
'00 Black Dodge VIPER RT-10... "VINNIE"
Engineers do it with precision.
English teachers are novel lovers.
Home: larrysingeriii@comcast.net
SVX FEVER, CATCH IT AT A MEET NEAR YOU !!
Old 04-07-2003, 10:18 AM
Exclamation TS-1's are, I believe, Toyo's #1 "Ultra...
...High Performance" summer tire, so 25-30K would be pretty good mileage and comperable to others of this ilk, IMHO. A couple of Porsche 911 owners I know swear by them year round here in Oregon (I don't think they drive them much in the snow).
The TPT I was referring to has a 65K treadwear limited warranty and is available in both H & V speed ratings in 205/55-16 & H in 215/55-16. I'll probably be putting a set of these on my wife's 420SEL in 205/65-15 as my neighbor across the street has a net set and says they are the quietest & best tires he's ever had on any car.
Finding a pair of specifically matched used tires can be a problem sometimes, that's for sure!
' 92 SVX @ 185K
' 91 420SEL @ 223K!
' 87 F250 @ 180K
' 93 ZX-11D @ 29K
' 93 SC400 @ 93K
'85 F150 @ 135K
Old 04-07-2003, 11:34 AM
svx_commuter's Avatar
If I had to buy 2 new I would get all 4 and remember to rotate'm very other oil change, 7,000 miles. I am not that far behind you in buying all 4 new, again. I got the worn ones on the back for now.
Old 04-07-2003, 01:43 PM
JLittell
You can't be out of tires!!!!
Earl (a.k.a. "Wheels"), Same thing happened to me. The tires on my front were really misalign and worn funny on the outside of the tread. I moved both front tires to the rear, as I moved the rears to the front. I was hoping to go as long as I could until I replaced them. Like you, I would start all over and purchase or put on 4 newer tires. Try the Yokohama avs db "S2" (they are one of the best tires you could slap on the SVX). Keep rotating the tires as often as you get oil changes you should be good to go! I don't know if I could trust any alignment shop to do the SVX. Anyone else have any recommendations? I guess I would trust a Suby dealer.
Old 04-07-2003, 02:28 PM
RSVX RSVX is offline
Network Design Administrator
Please dear God dont do what I used to and replace 2 @ a time. I always would keep the new ones on the front and recently it ended up costing me just over $900 to fix my transfer clutches n stuff...
Life is a game. Play to win.
That is who did mine. I took it to a local suby shop and they did a good job on it. The previous owner had it done twice and was not happy with the joby that they did. Well, I don't think that they did the front at all because the suby shop had a horrible time breaking the tie rods loose. They said that they didn't think that it had ever been done.
Unfortunately, the tires were already down to the belts, so I can not run them at all. I have the stock wheels and tires that I bought from him on it now. This will get me by until I can get all 4 new tires. (225/45 17) I don't think I can get Yokohamas that size.
Old 04-07-2003, 04:27 PM
JLittell
Nope can't get Yoko S2 in a 17". I wish I could!
