Old 03-16-2003, 06:43 PM
Subafreak's Avatar
Superbeast
Where's the bleeder?
Does the bleeder on the T-stat go up or down? Forgot to look when I took it out.
Old 03-18-2003, 04:41 AM
svx_commuter's Avatar
Looks like the bottom.
http://www.subaruparts.com/diag/?mod...category=035-A
Old 03-18-2003, 10:05 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
If you want the air to bleed out I'd say at the top.
Old 03-18-2003, 12:53 PM
cbx-man cbx-man is offline
Re: Where's the bleeder?
If you mean the little loose piece that rattles, it goes UP.
cbx-man
'92 LSL Liquid Silver / Automatic Level-10 valve body mod / remote filter
'92 LSL Pearl White / 5 spd. IndigoSpeed 11# flywheel / ACPT Carbon fiber drive shaft
'80 Honda CBX in-line 24 valve 6 cylinder
Old 03-18-2003, 01:45 PM
kuoh kuoh is offline
I believe there is a notch in the pump housing for it.
KuoH
Old 03-19-2003, 08:29 PM
Subafreak's Avatar
Superbeast
Thanks guys. I originally put it at the top and then I saw that diagram and thought I might have done it wrong, but the diagram is misleading.
