Old 10-27-2008, 05:19 AM
svx_commuter's Avatar
Re: Grrr.... new tires installed, still vibration.
Originally Posted by Crazy_pilot View Post
Before I lose you with my long story, does the vibration come and go if you maintain a long curve on a highway? Will it sometimes be stronger, and then fade out, then later come back?
Being a tire monkey myself, I can say a few things about balancing wheels. While it isn't rocket science to roughly balance a wheel (well enough for a truck or big van, something with heavy ass wheels), getting it perfect for a more precise application can take a bit of skill, and the right balancer.
Here follows an overly descriptive narration about wheel balancing:
Your typical balancer will display the amount of weight that has to be added to the inner and outter lip of the wheel to bring it into balance, in increments of 0.25 oz. Getting the machine to say 0.00/0.00 is easy, but that doesn't necessarily mean the wheel is perfectly balanced. Some of the fancier machines will show a third reading, called "Total Static". This reading indicates the total single point weight that the wheel is out, and it reads in 0.01 oz increments. It is possible to have a wheel "zeroed" and still have a total static measurement of 0.30 or 0.40 oz, because the machine doesn't have anywhere to put a full 0.25 oz weight.
I had this problem when I mounted up the tires on my BBS rims. It was a busy day in the shop, so I got one of the other guys to balance them while I mounted. He was competant, but nothing special. Sure enough, first drive the car shakes from 60-65 mph. I come back, pull the wheels, and start re-balancing. The guy is ranting at me, and sure enough, the inner and outter lip measurements are zeroed. But! The total static was at least 0.3 for each wheel. To fix it I had to cut the weights down to smaller sizes than they come as and stick them on individually. Got 'er down to about 0.05/wheel. Smooth as glass.
And then there is Dave ""Earthworm"" who uses a bubble balance which takes care of the static component just fine. This is from his post >>""My dad and I installed the tires ourselves. I used a simple bubble balancer to balance them. Tested them to 220kph (~137mph) and no vibrations to speak of.""
I have had many people balance tires and then drive them to find out they are not really that good at speed. Bubble balancers are inexpensive and easy to use. I think I would use a tape weight in the middle of the rim on the inside to compensate for the static. After a good two plane balance is done this would be a check on the static.
Peace,
John
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 10-30-2008, 05:38 PM
Subix's Avatar
Subix Subix is offline
My Other car is a GENIUS Car!
Found a local guy who said he would do it for $50.
I'm going to pick up a loaded caliper from Napa permitting they have one.
Seeing as there is a brake caliper kit listed way below that, will I need that as well or just the loaded caliper?
Also, will having a new brake pad (loaded caliper) create any issues with the driver side, already half worn brake pad? Should I go unloaded?
Thanks in advance...
1994 subaru svx le 112k
Old 10-30-2008, 05:57 PM
Wikedjuggalo's Avatar
Rebuilding
Caliper isnt had you could save 50 dollars =D Bleed it is the fun part.
Old 10-30-2008, 09:19 PM
SuberNatural SuberNatural is offline
Bleeding was a pain... I got a set (4) russell speed bleeders and it was SUPER easy especially if you dont have anyone to help you. Well worth it IMO
1992 Liquid Silver/Black LSL
LeveL10 Stage 3 Trans and associated stuff
