Keyless entry/security
I went and bought a new remote (so now I have two of them) and was trying to program them useing the instructions provided with the owners manual. However, it will not go into program mode. Anyone have this problem? and what did you do to remedy it?
thanks
silver 92 SVX-"Hannah" -R.I.P. NOV. 1991-jAN. 17, 2003 red white and blue 2000 Suzuki TL1000-r-"Bethany" This grips me more than a muddy old river or reclining Buddha.(now running Metzlers! black 1987 Toyota MR2-"Helga" -Turbo conversion will now commence. 1996 Legacy Outback-"Gilda" white with brown trim |
The instructions in the '92 Owners manual are bogus, sorry to say.
Here's what you do: Turn the security system OFF (red light not flashing). Turn the ignition key to the ON position (without starting the engine), then OFF. Immediately begin pushing the security button on and off "rapidly" until the horn sounds and you hear a clicking sound from the glove box. Press the button on one remote twice (make sure the presses of the button are confirmed with the sounding of the horn with each press), then, press the button on the second remote three times (again, listen for confirmation beep). Then, turn the ignition to ON (without starting engine) and OFF again to exit program mode. Now, check your clickers. If the horn sounds four times in rapid succession and locks the doors, the security system is off and it is in "lock only" mode. If the horn sounds once, the system is on and you've locked your doors and armed the system. The horn sounds twice when you've unlocked the doors and disarmed the system.
Well, there is one thing you might try:
You put your left foot in, you take your left foot out. You put your left foot in, and you shake it all about. And you do the Hokey Pokey and you turn yourself around . . . Okay, enough nonsense (as if!). No, seriously, there is no "re-set" button, unfortunately. Did your other remote work before you bought your spare? Does the security system light flash on the button? The only other thing I can think of would be to disconnect the car battery for a while to see if that "re-sets" anything. Before that, you might try going through the "emergency by-pass" procedure outlined in the manual (that part is not bogus), then, try going through the programming procedure. Then, if that doesn't work, try disconnecting the battery. Those are all the things I can think of. Anyone else? Wouldn't it be freaky if the "Hokey Pokey" WAS what it's all about?
No, the old remote didn't work. I only thought about getting new batteries for it when I was at the dealer getting a new antenae.
No, the light is solid. I'll be doing the battery upgrade thingy ding tomorrow so I will be having the battery disconected for awhile. And , yes, I'll be trying the Hokey Pokey just in case
Yeah, I've had my battery unhooked for DAYS and did not have to re-program. Just thought it might kinda "shock" the control unit. The only other thing I can think of is removing the unit (but, I wanted to suggest it as a last resort) and opening it up and cleaning the "spring" and all the contacts on the wiring harness. In the past, all of those who've had their LED go "solid" have had to replace the unit or, it just "magically" started working again. Mine went south, I replaced it with a used unit. It worked for a week then, began to work intermittently. I removed it, cleaned the contacts on the wiring harness and the spring contact inside the unit (you might try cleaning all the electronics with a "no residue" cleaner from Radio Shack). I haven't had a moment's trouble since.
Ok, I'll give that a try. The Hokey Pokey didn't work(went all the way to the rear end part).
I took the switch out and proceded to dump the contents thereof onto the floor of the cabin Afterwards I cleaned it, and put it back into the place on the dash and it still is solid. Where is the security system located on the car? Maybe I can fiddle with it directly.
Same prob
My car doesn't go into programing mode either. This happened after I had it a the dealership for a few months. I think the screwed with it. I have the same symptoms as 249svx and have not been able to resolve the issue. Let me know what the results of taking the alarm out.
Thanks, Kevin |
Potential problem
I just got a new remote for my b-day and was eager to program it. I tried the steps a few times with no luck. Then tried again and it worked just fine. The only thing I remeber was different was that my foot was hanging out the door the first two times and the time it worked I was inside with the door closed.
Just my input. It worked for me Chris |
Re: Potential problem
Well, I think I might need to get a new one. Mine doesn't work. I took it out, cleaned it, checked the fuse, sat inside the car(both with and without the door closed), stood outside the car, sat in the chair upside down(hehe, just kidding)and it don't work. So needless to say, I need a new one Maybe I'll get one at income tax return time, but at any rate, the car still works and I'm not really worried about it. I did notice that it said 1998 on it though, so it isn't the first time it was out. Hope yours works for you kevin. Now it's on to the airconditioning problem
<<The only thing I remeber was different was that my foot was hanging out the door the first two times and the time it worked I was inside with the door closed.>>
Yep, doors, trunk, everything needs to be securely closed when programming the remote and setting the sytem. I remember screaming, shortly after I installed the second unit. It had been two weeks and the sucker didn't work. I was royally PO'd, then, I remembered I'd popped the trunk to get my duffle bag out. Felt like a fool ('course I often do). Got the bag out, closed the trunk, hit the "blipper" and all was well.
