Old 08-19-2013, 06:14 PM
SoobCrazy SoobCrazy is offline
SVX n00b
Re: OBDII Mt conversion???
Huskymaniac, I am working (slowly, due to fundage) on swapping a 5MT into my '96 and would be more than happy to try out your chip! Take your time with pulling those waveforms (within reason, 2013 would be nice, lol ).
Let me know what you find in the meantime and if I can help in any way, shape or form!
Old 08-19-2013, 08:53 PM
Huskymaniac's Avatar
Uses the ignore feature
I think I could whip something up quickly so let me know when you are ready for it. I may find time to monitor the waveform under more conditions but I REALLY hate hanging upside down and combing though those wires.
Tony
Old 07-14-2019, 06:03 PM
Dispatch20 Dispatch20 is offline
Bumping this topic from 5 years ago, as I'd like to add information relevant to the discussion. I've posted this on the SVX Facebook group but wanted to share it here, as well.
The OBDII TCU->ECM link is pretty simple, and not nearly as complex as others in this thread have speculated. Here are the basic facts:
  • The link is unidirectional from the TCU -> ECM. It appears to be a TTL-style push-pull signal (i.e. no pullup).
  • It is a single 5V digital signal that runs from the TCU to pin 80 of the ECM connector
  • It is a serial port stream but NOT a UART-style (e.g. COM port with standard baud rate and start/stop characters)
  • The bit rate is 10ms (very slow!) and repeats every 750ms. This means there are 75 characters (bits) in the repeating stream of data
I've observed 2 states with the use of a Digital oscilloscope as well as an Arduino computer setup to log the data stream. As noted above, there are 75 bits (10ms per bit) and they repeat indefinitely. The stream begins the second the key is in the ON position and continues after the ignition is started.
Here is a snapshot of the stream (a few traces of the signal are overlapped; I apologize!):
Park/Neutral sequence:
Code:
111111111100001100100100100100100100100100100100100100100100100100100101100
Reverse/Drive/2/3 sequence:
Code:
111111111100001100100100100100100100100100100100100100100100100100100100101
Notice the small variation in the code above for being in Park vs Drive. Also notice that the pattern in both cases starts with 10 '1's followed by a '0'. We can use this to our advantage in data logging.
YouTube video of digital oscilloscope is here: https://www.youtube.com/watch?v=1zMiSCoyKzw
I've driven the car while logging the TCU datastream and observed that no change in pattern occurs during shifting, throttle, or steering changes. The same pattern occurs in 1st, 2nd, 3rd, and 4th gears.
Given the simplicity of this, it seems feasible to do a 5MT swap and emulate this OBD2 TCM serial port link. It doesn't seem like the ECM needs it for much. So how would this be done? I used an Arduino Uno to record the TCU stream with the OBD2 automatic tranny in operation. I can use the same Arduino to transmit the patterns noted above into the ECM. This should prevent the CEL light for code for 5MT swaps.
Old 07-14-2019, 06:12 PM
In case you're curious and have some programming background, here is my Arduino C software for data logging the TCU data stream. To print out a nicely formatted line of data, I took advantage of the 10 repeating 1's followed by a '0' to synchronize my data capture. The hardware used is an Arduino Uno chinese clone that was $13 on Amazon.
I had to make a couple probe wires to stick in Pin 80 of the ECM and then into the Arduino digital connector pin #2.
Here is information on the ECM connector and a picture of my wire going into it. It's pretty easy to see and find but you need to be pretty flexible to stick your head under the dash.
You also need to create a common ground between the Arduino and the vehicle. I used some alligator clips on the cigarette lighter ground and then to a ground post on the Arduino. If you don't ground the car to the board nothing will work!
Here is a quick video of my prototype setup with the TCU wire, Arduino, and hacked together grounds: https://www.youtube.com/watch?v=F9ddmpcpLQs
Anyways, here is the Arduino software. And you can (hopefully) get the latest copy here: https://create.arduino.cc/editor/Dis...1e9984/preview
Code:
  OBDII SVX TCU Logger
  Reads the 5V serial data stream output from Pin 80 of the OBDII TCU
  The purpose is to record the TCU output stream and allow another piece of
  software to recreate the stream when the TCU is absent.  The primary use
  is to allow a manual transmission swap without throwing a check engine light
  for P1702.
// Use Pin 2 of Uno board to receive the TCU output stream.
int TCU_Output = 2;
// the setup routine runs once when you press reset:
void setup() {
  // initialize serial communication at 9600 bits per second:
  Serial.begin(9600);
  // make the pushbutton's pin an input:
  pinMode(TCU_Output, INPUT_PULLUP);
void loop() {
  int TCU_Val, Sync_Val = 0;
  // Sync up to data stream
  // O-scope showed a consistent 100ms of '1' followed by a '0' and the rest of the 750ms repeating sequence */
   while(Sync_Val < 96) {
    TCU_Val = digitalRead(TCU_Output);
    if(TCU_Val == HIGH) {
      Sync_Val++;
    } else {
      Sync_Val = 0;
      Serial.println("Not Sync'd"); // This should only happen on startup if the Arduino starts logging after the car is turned on
    delay(1); // 10x oversample for sync (e.g. 1ms sample rate on data that changes at 10ms)
    // About 95 milliseconds have elapsed which gets us close to 100ms.
    // The next 0 value after this will indicate the start of sequence.
    if(Sync_Val == 95) {
      Serial.println("Sync'd!!!!");
      Sync_Val++;  // Value of 96 will exit while loop
  // Stall waiting for TCU to push a zero after the 100ms '1' sync sequence
  // This should only be a few cycles (and you can let it print to serial to prove this)
  while(digitalRead(TCU_Output) != LOW) {
    //Serial.println("Stalled waiting for 0 after sync");
  // Once the zero is lowered, we will expect a new bit every 10 ms
  // So lets delay 5ms and sample at the middle of the data valid time (e.g. data is 10ms long, sample at midpoint)
  delay(5);
  // read and print out all 64 bits remaining (750ms - 100ms sync '1' - 10ms sync '0' = 640ms/10ms = 64 bits)
  for(int i = 0; i < 65; i++) {
      Serial.print('1');
    } else {
      Serial.print('0');
    delay(10); // 10ms bit rate.
  // Print a newline then loop back to sync
  Serial.println();
Old 07-14-2019, 07:25 PM
irox irox is offline
Nice! Thanks for sharing. I was thinking about trying to do something similar (arduino to fake the TCU for a MT swap). Ultimately I didn't get an OBDII car, so won't have them problem. But still great to you do (and share!) this, nice to know I was thinking along the right lines.
Cheers!
Ian.
Old 07-15-2019, 10:16 AM
SoCoNoHa's Avatar
SoCoNoHa SoCoNoHa is offline
H6 Fanatic
Keep the TCU connected, and wire in some 10 watt 1.5k resistors as dummy loads for the solenoids, and a 330ohm resistor for the temp sensor. That's enough to get the TCU for an EZ30 to play nice, bet it works for the SVX as well.
1992 SVX LS-L : King of the Stable
LGT 5MT, ABS Delete, Short Ram Intake, Custom Exhaust, Drilled/Slotted Rotors
1993 Legacy sedan : winter beater, supposedly.
1994 Legacy wagon : future drift car?
1995 Impreza coupe : EZ30++, daily racecar.
1997 Legacy GT : date night rocket?
2003 WRX : future winter beater
Old 07-15-2019, 12:17 PM
I bet that would work, too. Does anyone have the obd2 wiring diagram for the TCU?
Old 07-21-2019, 03:45 PM
FYI - Here is the OBD2 ECU and TCU pinouts:http://www.alcyone.org.uk/ssm/obd2pinout.pdf
Anyways, I am trying to make the P1702 check engine light come on to see how and when it happens. I cut the signal from the ECU Pin 80 (AT diagnosis data waveform), and it didn't throw a check engine light. I drove around the block a couple of times and let the car warm up, and no CEL. I drove it around again today with it cut and still nothing. I actually went and disconnected the entire TCU harness (3 connectors worth) and drove the car around again. It drove fine around the block and still had no CEL.
Any ideas why the CEL isn't turning on for this? My OBD2 scanner had no current or pending codes. People clearly get the P1702 when they do 5MT swaps, so I wonder if it is a combination of factors that cause it to be thrown? And not just the one wire serial stream?
My plan was to
  1. Cut the TCU<->ECU diagnosis signal and get CEL
  2. Clear CEL code
  3. Use Ardunio to transmit in the 750ms pattern I recorded during regular operation.
  4. Hope that CEL does not go on with Arduino running
  5. Do 5MT and use Arduino to keep the CEL off
Here is the cut wire with spade terminals for easy reconnection, and connection to an Arduino for logging the TCU, or emulating a TCU signal into the ECU:
Old 10-06-2019, 05:13 PM
Update: I previously had issues getting the CEL to go on for code 1702. I think the key is going on highway speeds for 10 minutes or more. Now that I can get the CEL to throw, I can test whether or not I can trick the ECM into thinking the TCM is in good shape.
Anyways, I put together a setup that can drive whatever signal it needs into the ECM.
I think the total cost should be below $50 to reproduce this:
Arduino Uno R3 clone - $12 (requires 5V-12 power, so you can't use the 14.4V from the car)
USB Type B 1.5" cable - $8
12V DC to 5V DC regulator - $12 (for powering Arduino via USB port)
Fuse Tap - $5
Here is what the TCM emulator setup looks like all connected together and ready for install:
And I loaded the following code I wrote on the Arduino:
Code:
  OBDII SVX TCU Emulator
  Transmits a sequence of serial bits to the ECU to prevent a check engine light
  when the TCU is absent (e.g. manual transmission swap)
// Use Pin 2 of Uno board to transmit the serial stream.
int TCU_Output = 2;
void setup() {
  // Output pin for ECM input data stream
  pinMode(TCU_Output, OUTPUT);
void loop() {
  // The TCU outputs 75 bits at 10ms for a 750ms cycle time
  // This sequence is what the TCU outputs when in Drive or Reverse
  char data_drive[75] = "111111111100001100100100100100100100100100100100100100100100100100100100101";
  // This sequence is what the TCU outputs when in Park or Neutral.  May not need to use this.
  char data_park[75] = "111111111100001100100100100100100100100100100100100100100100100100100101100";
  // Print out the entire sequence
  for(int i = 0; i < 75; i++) {
    if(data_drive[i] == '1'){
      digitalWrite(TCU_Output, HIGH);
    } else {
      digitalWrite(TCU_Output, LOW);
Here is what the fuse tap looks like. The 15A blue fuse is for the radio, and the gray fuse is a 2A one I am using for the 5V Regulator and Arduino.
Here is the fuse tap inserted into the Radio fuse. This is one of the few fuses that has no power when the key is in the OFF position. You wouldn't want the Arduino powered up when the car is OFF! Also, you need to be careful with fuse taps. If you install it backwards it bypasses the fuse! Use a voltmeter to find the "hot" side of the fuse. You can see the orientation and location of the fusetap that I chose below. Also, note the metal nut at the very bottom of the picture; that is what I used to ground the regulator and Arduino.
Note: I had to Dremel the fuse tap skinnier so that it would fit into the fuse panel. I must have had the wrong size/shape fuse tap.
The fuse panel cover does fit over the installed fuse tap as long as I dremeled out a small portion near the latch.
Old 10-06-2019, 05:22 PM
So I installed the setup. I ran a wire (purple) from the Arduino up to the ECM, and powered it all up (black wire to fuse tap in fuse panel):
I proceeded to take the car on a long cruise, and unfortunately I read out a "PENDING 1702" code, so something isn't correct yet. That's to be expected given this is such an experiment.
I must be missing something (or a few things). I'll need to do a full highway drive with the Arduino logging the TCM signal, and comparing that to what the Arduino is outputting.
I'll post back again when I learn any more about this. I realize this isn't a hot topic, but hopefully people find this interesting!
Old 10-06-2019, 05:35 PM
It is interesting indeed. Don't be discouraged by the lack of activity on this site. It has gotten that way in the last couple of years.
1997 Bordeaux Pearl, 2010 Mercedes Benz GLK350, 2018 BMW 640i GT Xdrive, 2012 Moto Guzzi Norge GT 8V,
Old 10-06-2019, 06:53 PM
I think there are lots of people that would love to see this figured out.
Old 10-08-2019, 12:48 PM
theflystyle's Avatar
Im not able to provide any useful commentary but I wanted to let you know this is a very interesting thread
1994 SVX LSi
2008 Legacy 3.0R
Old 10-11-2019, 07:37 PM
92 SVX 92 SVX is offline
I can tell you if there was a like button I and many others would have mashed it...
speaking of likes have you posted your findings on svx nation on facebook? I know currently that is the hotspot for svx activity.
Old 10-12-2019, 02:45 PM
wdb wdb is offline
dances with roads
Another "Like" button presser here. Keep us updated!
1995 Caterham 7 Twincam
2007 BMW 328i Cabriolet
2012 Tacoma 4wd v6 Access Cab
