Old 04-07-2003, 07:35 PM
Vern!
Digital temperature gauge
First picture of my digital transmission fluid temperature guage. Normal "at rest" temperature is 160F-170F on a warm day. Under hard driving it may be 180F, with spikes up to 200+ once I stop the roadway shenanigans and the airflow rate through the cooler decreases.
The guage was purchased from Dakota Digital ( http://dakotadigital.com/Detail.cfm?...umber=ODY-08-3 )
Old 04-07-2003, 08:39 PM
Nice choice
If you wanted to (it takes some work and isn't perfect) you can put the gauge there the change holder is.
Here's my install:
http://dcss.dyn.dhs.org/pics/current/Im001734.jpg
Old 04-07-2003, 09:13 PM
kuoh kuoh is offline
Soooooo tempting. I can also see that somebody had to park their car outside for the night.
KuoH
Old 04-07-2003, 10:10 PM
It reads that temp if it 40 deg F or so. It doesn't have to be outside to read that temp. It isn't real accurate at the lower temps.
Old 04-07-2003, 10:28 PM
Alycone's Avatar
Alycone Alycone is offline
Sue isn't really striped
That was the change holder? I'd wondered what it was.
Old 04-08-2003, 12:34 AM
My car is always outside. I live at an apartment. At the time the picture was taken it was in my dad's garage the same time the Stebro was installed.
Old 04-08-2003, 01:39 PM
Mr. Pockets's Avatar
Moderator
That's pretty similar to what I want to do, Dave - except that I want to use the coin holder as a matching bezel for the gauge. Did you have to cut the panel at all?
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 04-08-2003, 03:54 PM
I did not have to cut anything however I did have to take the gauge partially apart to mount it to the panel and the gauge must be installed on the panel while it is off the car. This results in the right side of the panel to not be bolted on and is being held in place only by the clips.
Old 04-08-2003, 05:24 PM
Re: Digital temperature gauge
i don't know how or where your temp sensor is mounted, but....
mine was mounted in a Permacool external filter, under the battery (near the engine.) ambient heat from the engine was giving it some false (high) readings. i wrapped the sensor with aluminum-backed foam tape to shield it from the heat. i noticed a 10-15 degree drop in tranny fluid temps after that.
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2013 G37xS (Obsidian Black)
Old 04-08-2003, 11:22 PM
Mine is located right before the inlet to the radiator.
