Old 03-25-2003, 09:12 AM
mbtoloczko's Avatar
sans SVX
interior lighting wiring diagram?
Does anyone have access to the interior lighting wiring diagram? If so, could you post it? I need it to fix a problem I created!
Mychailo
Visit my locker
Old 03-25-2003, 10:20 AM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
What did you do? Perhaps I can help. I have more wires in my car than most people.
L
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 03-25-2003, 11:03 AM
mbtoloczko's Avatar
sans SVX
L
When I was looking for a ground wire yesterday, I accidentally shorted out the circuit that controls the dome light and the little lights down by the feet when a door is opened. I had disconnected the connector for the foot light on the driver side, and when I was probing the terminals on the connector, I accidentally shorted the terminals with the probe. There are apparently at least 2 circuits controlling the interior lights because the dome light still works if I press the manual light button on the ceiling. The door light button on the ceiling no longer works though. I pulled and inspected the fuses in the engine compartment and down by the drivers' feet, and none appear to be burned out. I'm guessing I either burned out another fuse that I'm unaware of, or I burned out the switch. What are your thoughts?
Mychailo
Visit my locker
Old 03-25-2003, 12:42 PM
kuoh kuoh is offline
You probably shorted out the output transistors in the lighting timer module. The dome light switch still works because it's in parallel with the timer circuit. If you're handy with a soldering gun and have a source for the transistor, you might be able to repair the module. Otherwise, you're going to have to buy a replacement.
KuoH
Old 03-25-2003, 03:02 PM
mbtoloczko's Avatar
sans SVX
KuoH
Do you know the location of the timer module?
Mychailo
Visit my locker
Old 03-25-2003, 03:35 PM
See
this thread.
KuoH
Old 03-25-2003, 04:55 PM
mbtoloczko's Avatar
sans SVX
See
this thread.
KuoH
Cool. Thank you!
Mychailo
Visit my locker
Old 03-26-2003, 12:57 AM
mbtoloczko's Avatar
sans SVX
See
this thread.
KuoH
I was just looking around at Subaruparts.com, and it appears that for the '94 and later SVXes, the dome light timer may be in a different location:
http://www.subaruparts.com/diag/?mod...category=835-1
It looks like part "M" or "88001 #2" is what goes on my '95 SVX. Do I have this correct?
Mychailo
Visit my locker
