Old 03-16-2003, 01:13 PM
CigarJohnny's Avatar
Question cruise control and washer that don't
When I picked up my SVX at the dealer (where it was diagnosed) to take it to the other place to get my tranny swapped out, I noticed the cruise control suddenly didn't. After I picked it up from getting the tranny swapped I noticed that the front winshield washer doesn't either. What is frustrating is that the fuses are not blown but the washer motor doesn't come on but the wipers do when you push the washer button. The connections look good. As for the cruise, the cruise light comes on in the switch but it will not engage. I don't know where to begin trying to track that one down. I have to get new batteries in my tester before I can begon tracking things down.
Does anyone advice on what to look for or have diagrams for the cruise control system and/or the windshield washer circuit? With the weather as worm as it is and all the snow melting, I absolutely have to repair the windshield washer ASAP.
Old 03-16-2003, 01:31 PM
The vacuum line at the firewall probably disconnected fron the vacuum modulator, a common occurance. Someone probably knocked it off when checking the tranny fluid.
There is a horizontal cylindrical part attached to the firewall, to the left of the brake master cylinder. There should be a vacuum hose which plugs into the right side of this part. Look for an unattached vacuum hose close to it anf plug it back in. Thats all
Old 03-17-2003, 10:43 AM
mhl0125 mhl0125 is offline
Send a message via AIM to mhl0125 Send a message via Yahoo to mhl0125
Are you referring to the vacuum for the widow washers or the cruise control? When I depress my cruise control button, it lights up, but I can't get the cruise to work at all. Is there a fuse for this or something else I should check?
Michael
1994 Barcelona Red SVX-LSI
Two-owner:169K
1995 Emerald Green SVX L AWD
#80 - Custom intake w/cone filter
99K with killer stereo system
2002 Acura MDX-Touring Edition w/navigation
2008 Toyota Prius
1987 Mercedes Benz 560SL
Old 03-17-2003, 11:54 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
He's talking about the cruise. As for the washer, you are pushing the button on the end, and not pulling on the stalk, right (did this for a while and drove myself mad. Didn't discover the mistake until I'd purchased another motor. )
Randy Johnson
Mike Davis -- at Reading VI
Old 03-18-2003, 05:09 AM
I have exactly the same problem with my cruise. All the lights but no control. If I solve mine I will be sure to share the resolution with you.
Old 03-18-2003, 05:16 AM
No, Randy, I've been pushing it. They used to work until after the work I had done. I wouldn't put it past the place I had it worked on to detach something so I would bring it back. I don't see anything loose so I'm hoping someone has a diagram of the washer system so I can troubleshoot it accurately. It could be the motor but I want to make sure before I purchase a new one. First I need batteries in my tester so I can verify power to the motor.
