Old 10-15-2002, 07:48 AM
Re: Don't get it
Originally posted by Myxalplyx
I don't get it. 1 second the guy is holding a gun with both hands saying something. Immediately afterwards, he's holding a bear or something running after the SVX.
As for the handbrakes, wouldn't the rear wheels have locked-up during that move? It looks like the rear wheels are turning the whole time throughout the whole manuever.
If you stop/start very rapidly using the space bar, you can see that the back wheels actually go in reverse for a half revolution while the car is on opposite lock.
Would not surprise me if the stunt driver had put in the two-wheel drive fuse for the stunt, and driven the car as an fwd model. He may also have selected and hammered reverse to break traction and cause the slide, a busted tranny is cheap if the director gets the shot he wants.
Lastly, don't forget this is the movies. Nothing to stop the stunt driver coating the rear tyres in washing up liquid or something slippy for the shot.
Old 10-15-2002, 12:46 PM
cbx-man cbx-man is offline
Re: Re: Don't get it
[QUOTE]Originally posted by svxistentialist
[B]
The back wheels rotating forward then reverse then forward is most likely a kind of an optical illusion. If you watch old westerns, watch the wagon wheels as they accelerate, the wheels look to be going forward then stop and then look to rotate backwards. It is similar to a strobe effect with the timing of the shutter speed of the camera to a rotating object. At least that's what Mr. Wizard says...
cbx-man
'92 LSL Liquid Silver / Automatic Level-10 valve body mod / remote filter
'92 LSL Pearl White / 5 spd. IndigoSpeed 11# flywheel / ACPT Carbon fiber drive shaft
'80 Honda CBX in-line 24 valve 6 cylinder
Old 10-15-2002, 05:17 PM
Strobe effect
Quite right CBX, I did think of that, and it is very possible. If you could see the front wheel also doing it, and you can't because of the angle, it would confirm this hypothesis.
I wonder though if the film was shot using film stock or video?. The effect depends on the number of frames per sec synchronising with the strobe effect of the wheel like you say.
I is a nifty bit of flinging the car about though, isn't it?
