Old 05-09-2011, 01:08 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
where's the best place to run wire?
i'm about to finish my subwoofer and i need to wire it to the battery. where is the best place to run 4awg wire from the battery to the trunk? forgive me if this was asked and solved elsewhere, but i couldn't find it.
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 05-09-2011, 01:30 PM
Cam Cam is offline
Re: where's the best place to run wire?
I ran mine through an existing grommet in the firewall, down underneath the carpet along the driver side seat, along the side all the way back to the trunk.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 05-09-2011, 01:34 PM
B 4 You's Avatar
#lolsvx
did you have to drill any holes? could you post a picture (if you have one), and did you have to remove anything from the engine bay to access it?
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 05-09-2011, 01:38 PM
Cam Cam is offline
I was able to get it through the firewall fairly easily. I dont remember if i used a coat hanger or what...I definitely did not drill any holes. No pics of that, sorry. The grommet is behind the driver side valve cover (give or take) and will drop the wire right behind the ECU, if I remember correctly. These are the types of tasks that allow you to be creative and developed problem solving skills, so the best advice i can honestly give you is to figure it out. If you are stille having trouble later i can take a pic when i fet home, but see if you can make it work first
Cam
'92 Ls-L Dark Teal
Old 05-09-2011, 01:42 PM
B 4 You's Avatar
#lolsvx
okay thanks! i'm going to go attempt it, if i can't i'll just ask for that picture.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 05-09-2011, 03:34 PM
B 4 You's Avatar
#lolsvx
i can't find it.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 05-09-2011, 06:14 PM
I don't know what grommet Cam used, I used the one the steering rack goes through.
I punched a hole with a screwdriver, fed the wire through.
Where I ran my wire:
Under hood view:
Under dash view:
Pics are from my stereo thread: http://www.subaru-svx.net/forum/showthread.php?t=54516
Maybe you find some other useful pics in it?
Old 05-09-2011, 07:07 PM
B 4 You's Avatar
#lolsvx
i was looking at that thread earlier today! i was contemplating on using that robber grommet on the steering shaft, but i was hesitant to poke a hole in it. how big was your screw driver? is there anything i could possibly do by poking a hole in there? i don't want to damage something. i have everything hooked up as of now, minus the wire from the battery to the amp.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 05-09-2011, 07:51 PM
I don't know if there is anything in there to damage, it looked like a rubber grommet to us so we used it.
We just used a a long philips head screwdriver that was just about the same size as my wire.
Old 05-09-2011, 07:58 PM
B 4 You's Avatar
#lolsvx
sounds good. i'll try that tomorrow. you didn't remove anything from the engine to reach it right? i think i can maneuver my hand in there. did you poke it from the inside or from the engine?
sorry for all the questions
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 05-09-2011, 08:24 PM
My friend poked from under to the hood. No we didn't remove anything to do it.
I was under the dash, and I could see the screwdriver pushing on the rubber, so I told him how to aim so the hole came out on the side so it was somewhat strait. Then he fed the wire while I pushed on the rubber from the inside to get it to the hole and pulled it through.
Maybe there is an easier grommet, maybe cam will have a pic.
Old 05-09-2011, 08:26 PM
B 4 You's Avatar
#lolsvx
well this one seems fairly easy. i think i can do this.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 05-09-2011, 09:02 PM
Cam Cam is offline
Sorry guys my car left me stranded at the workplace today...I am getting tired of that, let me tell you... Haha.
Anyways, I didn't take a picture. It was kinda the last thing on my mind, sorry. I will take a pic tomorrow during work if i get a chance, but the spot lookin4svx showed you is perfect.
Good luck, I hope the system sounds good.
Cam
'92 Ls-L Dark Teal
Old 05-09-2011, 09:31 PM
B 4 You's Avatar
#lolsvx
i'll be running it through there tomorrow. thanks guys.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 05-10-2011, 08:35 PM
B 4 You's Avatar
#lolsvx
ran it through successfully! thanks for the help! my subwoofer is up and running, and sounds amazing. i'm posting a bunch of pictures as soon as i can!
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
