Old 04-04-2011, 05:04 PM
MisterAl MisterAl is offline
Wrong power steering fluid
Hi, I left my 92 Lsl sitting outside over winter (Canadian). She started up first turn of the key a few days ago, but here was no power steering, and I found the reservoir was empty. I needed the car and without thinking, I found I had a can of regular power steering fluid, the kind that suits Gm, Ford, Chrysler etc (no other specification was on the container), and filled up the reservoir. I have only run a few miles since and the steering is moaning somewhat but working, so I guess the fluid is still leaking out.
My questions: 1) Have I done any damage because of using the wrong fluid? 2) Will just flushing out the system with ATF be sufficient?
Any help would be appreciated.
Old 04-04-2011, 05:29 PM
Cam Cam is offline
Re: Wrong power steering fluid
I would be more concerned about running it dry. How long was it running before you put the fluid in?
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 04-04-2011, 10:19 PM
Your O-ring is bad on the bottom of the tank. Look in the How-To Docs and it will show how to replace it. Cheap fix. Flush the system and go fom there.
Old 04-05-2011, 01:35 PM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Just drain it out and put good fluid in. One of my cars had the wrong fluid in when I bought it. I ran it like that for a long time. After I replaced it, the pump is a bit noisy and the steering feels a bit vague sometimes, but not bad enough to warrant fixing.
There is a hose join you can get at from underneath that is a good point for draining the steering fluid. Just separate it and run the engine for a couple of seconds and all the fluid will gush out. It's useful to have some kind of container to catch it in.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 04-06-2011, 09:06 AM
Thanks for all your help guys.
