Old 03-31-2011, 11:19 PM
Cam Cam is offline
ignition coils
If I am not mistaken our only option is OEM right? After installing the EUTUNE stage 2av1 today, I still have a rough idle. I pulled all the injector clips one at a time to verify connections, and every time the car stalled. It should run on only 5 cylinders, right? I figure I have possibly multiple bad coils. It runs decentush up top, but it does not idle correctly. I thought it was the cams, but I am almost positive its the coils. They are the only thing that was reused in the build that could causea rough idle. Also, I feel it should pull harder.
That being said, she sounds good and makes good power. I just think she should make more. And she sounds like she has an occasional miss.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 03-31-2011, 11:30 PM
Re: ignition coils
Do you have a CEL?
Old 04-01-2011, 04:01 AM
dragoontwo dragoontwo is offline
Re: ignition coils
It will limp home on 4 cylinders. I had the 2 front coils go on mine at the same time. What about the MAF?
'92 SVX LS Pearl White - 6mt
Old 04-01-2011, 05:44 AM
Cam Cam is offline
Re: ignition coils
Maf is fine. Just got replaced with a z32. No CEL.
Cam
'92 Ls-L Dark Teal
Old 04-01-2011, 09:07 AM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
Re: ignition coils
i had a bad coil once, didn't give me a check engine light.
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 04-01-2011, 09:09 AM
Cam Cam is offline
Re: ignition coils
Good to know, thank you.
Cam
'92 Ls-L Dark Teal
Old 04-01-2011, 09:17 AM
B 4 You's Avatar
#lolsvx
Re: ignition coils
same kind of symptoms too. super rough idle. went away at higher rpms. i didn't drive her though, i towed her to the shop, because i had JUST got her back from an oil change from my mechanic (who hates subarus and thinks my dad is a retard for buying me a car this fast for a first car) who i thought drained all the oil so the engine would seize.. turned out i wasn't putting the dipstick in all the way i hate being so paranoid.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 04-01-2011, 10:57 PM
Andrew P.'s Avatar
Andrew P. Andrew P. is offline
The Ebony ones are faster.
Re: ignition coils
Hey Cam.
I still have the old coils out of mine.
If you want to borrow them to troubleshoot, let me know.
92' Ebony. Magnaflow exhaust, tinted windows, STI wheels, 97' grille, Bontrager Works SB, ECUtune transaxle and TCU.
77' IHC Scout SSII
Old 04-02-2011, 12:00 AM
Cam Cam is offline
Re: ignition coils
Sounds like a good deal to me Andrew. We'll touch base. Did you know which one was bad when you got your new ones?
Cam
'92 Ls-L Dark Teal
Old 04-02-2011, 05:04 PM
Andrew P.'s Avatar
Re: ignition coils
Unfortunately, no.
I'm not working this weekend so PM me your #
77' IHC Scout SSII
