Old 11-25-2009, 03:03 PM
"real" jdm spoiler ???
looks like a real one the seller has another so called jdm one that is green but its not the jdm shaped one
http://cgi.ebay.com/ebaymotors/JDM-S...item5633efd082
Old 11-25-2009, 09:28 PM
Re: "real" jdm spoiler ???
black one looks jdm, the green one looks like a regular US one. it's also cheaper, so makes sense.
does the jdm spoiler use the same mounting holes as the US one?
Old 11-25-2009, 09:53 PM
*EDIT
im not sure but they look like they are fairly close by comparison but i dont know ?
jdm (only):
link on first post
(rest of the world)dm:
http://cgi.ebay.com/ebaymotors/JDM-S...item3ef18bda22
Old 11-26-2009, 10:18 AM
Since both spoilers originate from the factory in Gunma it's a safe bet they are the same.
Also it is commonly presumed that the taller wrap-down-the-sides type of spoiler is the one and only JDM type because it was made available only in the home market for 91-93 models Version L and Version E. It is not generally appreciated that the "US type" was also available in the home Japanese market later on for the SVX.
So like they are both "real"
And the "US type" was also available in the UK, Australia and in Continental Europe.
just thought you should know these things.
Old 11-26-2009, 10:32 PM
Interesting, I had not read that before.
Old 11-27-2009, 03:00 AM
hairy's Avatar
hairy hairy is offline
Also it is commonly presumed that the taller wrap-down-the-sides type of spoiler is the one and only JDM type ...................... It is not generally appreciated that the "US type" was also available in the home Japanese market later on for the SVX.
It's true you know.....................here is the spoiler on my '95 JDM.
Old 11-27-2009, 04:16 PM
Green1995SVX's Avatar
Yes, and no. The JDM type wing uses two of the same holes, but the other two must be drilled out to accommodate it. If you open your trunk lid and look inside, you can see where you're supposed to drill the second set of holes.
Mike
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
