Old 01-24-2010, 07:47 PM
michael's Avatar
michael michael is offline
What Potholes ???
Re: unfinished oem rarities list. Help me out you svx crazy people.
I could be wrong, but I believe these are a universal fit.
Wanted: Steering Wheel
Old 05-05-2010, 05:58 AM
I thought I would post it here. I finally found the Uber rare OEM Radiator with Aluminum tabs. I mentioned it quite a few times on the board, but no one seemed to know what I am talking about
I have seen it in person, checked its thickness and I can confirm that it is just the OEM rad + aluminum tabs intead of plastic. I don't know if it was OEM Subaru or just a modified from OEM.
Here is the pic:
And HERE is the link (just an SVX ad in Japan).
BTW, Earl you might want to note the Vin.
Old 09-11-2017, 03:30 PM
Go up.... lots of dust...
Guys need the part number of the headlights protectors. Trying something...
Thx
Old 09-11-2017, 04:26 PM
Thx
The only number on them was SCI 700204.
http://www.subaru-svx.net/forum/show...hlight=shields
14 years old and look as good as new.
Old 09-11-2017, 05:17 PM
My daughter had a '97 Outback with the same type of headlight protectors. They were fantastic. The headlights underneath were like new.
1997 Bordeaux Pearl, 2010 Mercedes Benz GLK350, 2018 BMW 640i GT Xdrive, 2012 Moto Guzzi Norge GT 8V,
Old 09-24-2017, 02:49 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
OEM CD stacker holding bracket frame with SVX logo on the side, it fits at the base using the 2 holes near the side opening (where the antenna drain pipe fits) and then also connects to the actual antenna mounting point.
Note that my car has a removable door to get to CD stacker, other interior mats do not have this option - hence the add-on stacker holder that I am showing you.
Old 09-24-2017, 03:10 AM
SURTEESS's Avatar
Since someone has brought up the side indicator light mounted on the front wing, what about the non-USA front wing - without the indicator light hole, got to be rarer than the USA version?
