  #31
Old 12-18-2007, 06:49 PM
Wikedjuggalo's Avatar
Rebuilding
Originally Posted by Psychosis5150 View Post
Missed your post about trying that, sorry.. You should still list what exact hardware your using, mobo, ram, vid card, power supply, processor, etc.. that would help alot. Another thought, is your processor a P4? If so do you have the small 4 pin power plug hooked up from the power supply to the mobo? Yet another thought would be to try some different ram if you can.. I've had some ATX power supply plugs have a pin or two come partially out too.. Just throwin ideas out there for ya.. If your feeling really brave you could always try loading Linux. It's no good if your a gamer, but for surfing, media playback and office apps it works pretty good, it even works with ipods, and its free.. I've been running Kubuntu linux for a few months now, and like it enough to get rid of windows completely. You can download it as an iso, burn it to cd, and boot from the cd to a semi working desktop to test it, all without installing.
You want a list huh? lol O.k. Yes I had to use an adapter of the Processors power, because it can use 4 pin but the 4 pin on my Powersupply was well backwords lol . As far as Linux, I would, I'd love to, but I am a gamer. Until windows stops dominating the market, I am stuck with it.
Motherboard: Foxconn C51XEM2AA 590 SLi
Memory: 2 x 1GB Kingston HyperX
CPU: AMD Athlon x64 2.8 Ghz Dual AM2
Hard Drive: Western Digital Raptor (10,000 RPM's) 150GB I love this HD!
Video Card: EVGA 512 MB Geforce 8600 GT
Power Supply: a "Turbolink" 500w - came with case
And just in case you were wondering
DVD: Light On 20x DVD/CD etc.
and a Floppy drive
Old 12-18-2007, 07:12 PM
Psychosis5150's Avatar
Psychosis5150 Psychosis5150 is offline
Yugo aficionado
LOL nice! I didn't have much luck searching for that error with your board.. One thing I did run across is setting the FSB lower, basicly underclocking the processor. If that helps I'd suspect the processor. I know AMD's are really sensitive to heat, any power to them without a heat sink/thermal compound and they go up in smoke..(don't ask..) Did you ever update the bios, or reset/select factory defaults? Any chance you can get ahold of a different copy of windows? You seem like you know what your doing, I'm just rambling off ideas now, hoping one might help..
92 Teal 181K
4:11 trans
Lightweight crank pulley
Redline Shockproof
Trans Cooler
Viper 550 HF Alarm/Remote Start
18" Enkei Evo5's
Old 12-18-2007, 07:18 PM
Rebuilding
Um, I am going to attempt a BIOS flash again, reinstall windows (Wiping the hard drive and reinstall). Like I said I do not think it is the Hard Drive, as I did WD tools to test for errors. I am 90% sure its the motherboard in some sort. Good news is I have a year replacement form newegg on it if it needs to be RMA. I am going to have Foxconn call me tomorrow and maybe (if the BIOS Flash, reinstall doesn't work) they can help. I want to have BIO flashed before I call them in case they tell me too I can already have it done.
TESTED:
Hard Drive using Western Digitals Tools, Also used another Hard drive getting the same error as before.
Memory passed the memory test.
Errors:
Motherboard hangs sometimes on loading ACIP
Soon as It trys to load windows I get 0x7e error / BAD_SYSTEM_CONFIG_FILE
By the way like the setup?
Old 12-18-2007, 08:56 PM
If I were you (and have been in the same spot before) I would go to some place like FRYs or best buy and buy a new mother board for testing purposes. It is a quick and easy way to determine what hardware is at fault and if you don't destroy anything you can just return what you bought the next day for a refund. I use the excuse of finding a better deal somewhere else when they ask why I am returning the product. I was given this idea by a guy from the tech support of the company who made my bad board. He said that it was quicker than trying to RMA the thing, which it was.
blk 92' LSL w/ average mods
Old 12-18-2007, 09:02 PM
Rebuilding
I like your thinking! I might do that, I still going to have to contact Foxconn.
Old 12-20-2007, 11:55 AM
greggbzz's Avatar
greggbzz greggbzz is offline
Awitha Cheese-ahhh!
Send a message via AIM to greggbzz
http://support.microsoft.com/kb/330182
If the computer is getting this far, and the result is consistent, and you've tried swapping hardware around with the same results, it really smells like a software issue.
Likely, your registry got corrupt, which can happen sometimes during an abrupt shutdown while writing to the registry. Or, perhaps, a bad Win32k.sys file.
Have you tried booting in safe mode?
Old 12-20-2007, 12:01 PM
Rebuilding
Thanks for the help but I can not even get to that point. I tried. As soon as it goes to start loading Windows off the HD it gives me the blue screen. I have gotten the same message on a different HD. I tested memory no avail. It has to be the motherboard or Processor. but I doubt its the Processor. Foxconn has not called me yet so IDK whats up.
Old 12-20-2007, 07:06 PM
If you want to go software then try this out.
http://www.ultimatebootcd.com/download.html
Old 12-21-2007, 02:21 PM
CigarJohnny's Avatar
Try these sites, they may help you:
http://www.techspot.com/vb/topic79199.html
http://www.aumha.org/a/stop.php
http://support.microsoft.com/?kbid=321637&sd=RMVP
Best of luck
Old 12-25-2007, 07:50 AM
Ownbot's Avatar
Ownbot Ownbot is offline
I'm the anti-do-gooder
If you make through the BIOS booting, then you should be able to load windows.
Old 12-25-2007, 12:06 PM
Rebuilding
Thats what I am confused about. But I am going to have to RMA the motherboard. I believe the problem lies with in that and possible one of the components on it going bad. I have tested everything ; ;.I switched hard drives. I flashed Bios, and I tested memory. If Foxconn ever contacts me -.- I guess I'll go to Newegg next. It sucks my computer was awesome. Well I am RMA the motherboard I"ll boots my power supply. I have wiped the Hard drive and reinstalled windows. If RMA don't work i will just blow it up I guess. or Part it out lol.
Old 12-25-2007, 01:56 PM
Seraphinwolf's Avatar
Seraphinwolf Seraphinwolf is offline
H6 THE ONLY WAY!
Send a message via AIM to Seraphinwolf Send a message via Yahoo to Seraphinwolf
Double check BIOS is my vote.
I"ve gotten pretty used to having to fix these kinds of situations with my system. I also keep fighting the upgrade itch. I built my system in 03 and other than adding like 138mb or SDram I haven't changed a thing. The last time i spent 3 days pulling my hair out trying to get it to work. Finally before reconfiguring the whole thing I checked the one thing I put off cause it was "too simple to be the problem." Went into BIOS and found the bios reset the settings on what HD it was reading. So it wasn't reading anything hooked up or not. I'd try this or bring it to someone that can diagnos it. If they don't have an answer or the answer is it's time to start up the microwave you'll save a lot of time. If you aren't familar with working on the Bios(you said you built it so even vaugely familar you can pull out the boards book and figure it out)or you can't and picking up a book on BIOS would be helpfull. Most Blue screen errors are Bios related or a loose connection. Good luck
-Gaddis
94 Bordeux Pearl LSi (Jun 2009) 109k Plate:GADDIS
What they call it a vanity-plate. Shouldn't I be obligated to be vane with it?
Rota Tarmac 3's 18x8" on 245/40/18 Dunlop SP Sport 600's, Perrin light weight crank pulley, PRW radiator, custom coilovers(not GC's), 9006 HID 4300k 50W low beams, DIY garage door lip, and SVXfiles brake kit. Fixxed exhaust so no more sweet sound.
97 White/Black trim Impreza Outback Sport (March 13/08) 150K-180K(sensor broken)Good news is EZ30R and 05' 6speed full powertrain swap is in motion!: Will be doing more work as I can. Gonna be run by a Hydra so yeah fun to be had.
[SIGPIC][/SIGPIC]
-Gaddis
Old 12-25-2007, 02:37 PM
Rebuilding
-Gaddis
Well, I have go in and disconnected everything, Flashed the BIOS and even ran all diagnostic tools I could find that were reliable. I think if I have to RMA it I will also upgrade power supply. I am pulling my hair out as something I spend much time and money in should work.
Also my Sub woofer and Amp I ordered got sent back and am waiting for a call from Circuit City from their Faud Center because Fedex screwed up the delivery.
Old 12-25-2007, 03:43 PM
PaulDexler PaulDexler is offline
Bsod
Hi,
Just some thoughts. My machine has been running for almost three years now since I built it, and it's pretty reliable. But... I bought all the parts from Fry's, which was good, because there were a lot of exchanges at first. When it first came up, there were intermittent BSOD errors, turned out one of the two hard drives was bad, and of course it was the one that ran my "C" partition. (I have two 160GB SATA drives, with 5 partitions.) Then a few days after that, another BSOD. This time it was the PS in the Antec case. Put in a larger one, and was OK for another few days, then problems again. Finally pulled out the Mob, and replaced it, and that configuration has held up for more than two years. I just maxed out the RAM to 3GB, and I am running an Athlon 64 at 2.8Ghz. Anyway, the Mob was the final culprit.
Just ruminating.
Paul
The great white fleet:
'91 Alfa Romeo 164L 5-speed
'92 Subaru SVX LSL
'93 Mercury (Aussie) Capri
Old 12-25-2007, 03:46 PM
Rebuilding
Originally Posted by PaulDexler View Post
Hi,
Just ruminating.
Paul
You kind of confirmed what I suspect is the problem. I will be replacing the Power Supply and most likely RMA the motherboard. If that does not solve it , well I will have something fun to run over with an Explorer.
