Old 05-05-2002, 05:38 PM
lee lee is offline
Unhappy no movement - forward or reverse - help!
Background: My front differential case failed. A part of the housing cracked off and got between the gears, chewing up the ring & pinion.
Since I had no core to work on, difficulty in finding gears, etc., nobody around here wanted to touch it. So I bought a used unit from an out-of-state wrecking yard.
Installed the unit, but get no movement from drive or reverse.
Have tried putting in the FWD fuse, no difference.
Any ideas beside having it towed to a tranny shop (I can swap things out, but no experience in automatics rebuild)?
tia, lee
Old 05-09-2002, 05:26 AM
svx_commuter's Avatar
Very sad to here of your problem. From what I understand it is very hard to find a tranny in the junk yard. BUT BUT BUT 5spd Huck says the legacy front and rear dif's fit right in the SVX housings. You want a faster SVX? Don't care about gas milage?
I do not know about the case, if it is the same?
Was your RWD working?
Old 05-09-2002, 09:52 AM
lee lee is offline
yes, the RWD was working.
Found a transaxle, working over some hints supplied by Stevebsy on proper installation.
