Old 04-28-2002, 08:14 PM
window troubles
my drivers side window makes a "clunk" when it reaches the end of travel going down. is there a bumper or something that is screwed up or missing? also, i have some light vertical scratches developing on the outside of it. some sort of window guide worn or missing? i looked at subaruparts.com, but didn't get any clues. thanks for any help!
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2013 G37xS (Obsidian Black)
Old 04-28-2002, 08:36 PM
gcookaustin
I have the same scratches on mine; seem to go away when washed. Mine sort of makes a little clunking noise but I thought it was normal..
Old 04-28-2002, 08:41 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
There are two (if I remember correctly) rubber-covered travel limiters at the bottom of each door. Usually the rubber splits and falls off. Best bet is to use a short piece of vacuum tubing, split lengthwise and glue it in place with contact cement.
There are also two window pads that rub against the outside of the glass that tend to collect debris and scratch the glass. While you have the door panel off repairing the travel limiters, lightly pull the glass towards the inside of the car and clean the pads. Personally I like using a steel pick and a blow gun, but many have found other methods.
Old 04-29-2002, 07:31 PM
thanks AGAIN, Beav!!!!
Old 04-29-2002, 10:34 PM
MoreIBNR MoreIBNR is offline
Original Owner 1992-2008
Send a message via AIM to MoreIBNR
I found it works best to remove the inside pads - there are just a couple of bolts holding them. That gives you enough room to pull the glass away from the outer pads. I used an old toothbrush (yes, you could use a new one, or even the one you are using every morning - it doesn't matter) and canned air.
Old 05-04-2002, 10:25 AM
gcookaustin
Should the windows be rolled up or down when cleaning the pads?
Old 05-04-2002, 11:08 AM
Beav's Avatar
Not as old as Randy
Definitely down - you need to remove the door panels first though. Thanx to MoreIBNR for catching my oversight - forgetting to remove the inner pads to allow access to the outers.
