Surging when accelerating / a minute or so after starting
My start & stall problem seems to have diminished, and I just ease onto the accelerator after starting to make sure it goes. This morning when I was out in search of a front brake job I started the car and shifted into drive or reverse or something, and it seemed to shift a lot sooner than normal. As I accelerated to the red light (in gear 1) the engine seemed to "surge" on and off (It didn't make a noise, but if it did it would go 'RRRRrrrrrrRRRRRRrrrrrrRRRRRrrrrrr' and so my acceleration was about like that. If that is not abnormal then okay; but it seems like this car does something funny about every day and irons itself out. Just trying to prevent something bad from happening...
...speaking of which, I'm certain that this car has not had the 60k service. Can anything extra bad happen as a result of that? Some of it I can do myself (coolant flush) but I ain't touching that timing belt. |
You know, I had that issue too, but it only happened during the period of time between a cold start and operating temperature. In the past two days, it has been doing it constantly, but in a different fashion; at almost exactly 1200rpm, it hesitates hard, then surges to 1500 and is good from there.
My theory: The cold start issue is a fuel pump/regulator/filter problem. Somewhere along the line the fuel PSI is not steady methinks. As for my new issue... I think my torque converter/transmission is not a happy camper to the 90 degree blast we've had in MA the past few days. It's an almost brand new tranny. Has roughly 20k on it. Since the new transmission I have babied it as much as can be.... perhaps it's not too late for a tranny cooler?? Anyone want to comment/throw in much needed suby wisdom? -Sz
1994 SVX LSi - Black / Beige - 139k miles SOLD! 1999 Chevy Camaro Z28 - Black, 6-speed, hell of a ride. 2004 Chevy Silverado Z71 - Blue LT2 luxury package |
Hey Szalkerous,
Where in Mass are you located? I was just wondering where you were maybe we could meet up sometime. I go to Umass/Amherst. Thanks Jerad |
I get that every day when I start off. and its been about 40-50 degrees every morning. it seems to only do it in the morning for me. When I first start it up. And it seems to do it less when I have a full tank of gas. I just figured my injectors were dirty. I just haven't had any money to buy cleaner for them. Maybe I'm wrong.
Mine has done the surging thing since i've owned it. I dont let it bother me. One of these days i'll look into it, but until then... F it.
-Mike |
My thought was fuel filter. I'm gonna replace that sometime soon. I'll keep y'all posted.
-Mike |
Mine's always done the surging thing too.
I've had the fuel filter replaced twice and it hasn't seemed to help. I run injector cleaner through it and it seems to be better for awhile. --Michelle
~~Michelle ----------------------------------------------- '92 LS-L - copper - 190K miles '94 LS-L - pearlie - 92K miles *still have '92 parts* |
I found a few minutes this afternoon to check the fuel pressure and flow, look for vacuum leaks and generally get wet doing so in the rain. All for naught, all was well. However the car seems to have gotten over whatever it is/was, it's running fine today. Kinda hard to fix something when it isn't broken.
Driveability problems have been a bear this week, everything coming in the shop has been weird. That and a lot of new customers drifting over from the K-Mart, now that Roger pulled the plug. The way things are going with them I wish they'd drift over to somewhere else...
ASE Certified Master Automotive Technician w/L1. ASE Certified Master Medium/Heavy Truck Technician. Certified EVT (Emergency Vehicle Technician) Last edited by Beav; 04-19-2002 at 04:45 PM. |
Has anyone figured out why the engine surges? It's worse when I first get moving, but even last week after traveling on the interstate for an hour I noticed that it still does it a little; I had to slow down for construction traffic and in 2nd gear at constant speed you could subtly go RRRRrrrrrRRRRrrrr..... I'm running some injector cleaner through now; the Check Engine light came on soon after I put some in and then it went off so I guess it's doing something...
Any answers?
Did anyone figure out the problem?
no answers here, but I have the same problem. Mine is obvious when the car is cold, and maybe sometimes there once warmed up. I was reading a 300zx forum a while back and it suggested that surging (on the 300zx) could be due to all the things we mentioned already, OR it could be due to a faulty engine temp sensor. If I'm not mistaken, our engine temp sensor is on the front of the engine under the alternator. The ECU gets a signal that the engine is warm, but it's not, so it runs wrong...something like that. Any comments?
-Mat
Time for my very own long list of mods: 92 SVX LS-L - Ebony Pearl - 2002 WRX 5MT trans w/STi gearset (rebuilt & installed myself ) - BMW E46 HID retrofit - Kenwood Headunit - Phoenix Gold 75x4 RMS amp - Alpine Type R 6.5" front components - Alpine Type R 6x9 3way rear speakers - 18"x9" Rota G-Force wheels w/225/40ZR18 Toyo T1R's - Mychailo's custom springs - Urethane front & rear sway bar bushings - KC exhaust (2.5" dual magnaflow) - Escaine seat swap - Removed Spoiler I don't care if Subaru says it's STI...it will always be STi to me |
thermostat is broken, or so i thought
hummm...thats an interesting comment.
i thought my thermostat was broken this winter. the engine would not heat up unless i covered the grill. hummm..... |
No the thing under alternator is oil pressure sensor. The temp sensors are on the left (driver) side back of the engine. There are two of them next to each other - one for ECU, the other for the gauge on dashboard. So in theory we all could have gotten a bad temp sensor for ECU, but a perfectly normal one for the dashboard indicator, but I find this kinda hard to believe. |
