Old 11-26-2006, 12:10 AM
US to CDN SVX's Avatar
US to CDN SVX US to CDN SVX is offline
SVX Voyeur
At how many Miles did you replace your Fuel Pump?
At how many miles did you replace your fuel pump? I still have low miles but I was thinking of changing it before it dies as my Volvo's just crapped out at 155 Miles.
Also I presume it is in the tank?
Thanks
1992 SVX LSL Peacock 94,000Miles
1981 VW Westfalia 166,000Miles
1995 Volvo 850 Wagon GLE 174,000Miles
1981 FIAT Spider 120,000Miles
50% Boxer
Old 11-26-2006, 07:12 PM
hexadec0079's Avatar
hexadec0079 hexadec0079 is offline
Parts Breaker, Tire Waster
Send a message via AIM to hexadec0079
subaru fuel pumps rarely fail and in my experience the failure is progressive some times. Replace it around 150,000 to 200,000 miles. Don't worry until it fails, IMHO.
1992 SVX- -Drivetrain by BUDFREAK-
Green, LS with spoiler, 157,000, ES Swaybar bushings, 9005/6 mod, 2.25' Dual Exhaust, Custom Grounding, Hyperwhite fogs, LED tails, 4.44s, custom Blitz intake, tranny cooler, thats about it, for now...
1997 Chevy 1500 -FOR SALE-
5.7 liter, Z71, 300hp+, still almost 20mpg
1986 Merkur XR4Ti -SOLD-
SVO Engine, T3 hybrid turbo, K&N, custom ducting, Initial D painted, 18psi, fastest car for under $1000, ever.
Old 11-26-2006, 09:44 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
My SVX has 247K and, to my knowledge (unless it was replaced in the 109K prior to when I bought it - and there's no evidence that it has), the fuel pump has never been replaced.
Randy Johnson
Mike Davis -- at Reading VI
Old 11-26-2006, 10:05 PM
I have not heard of more than one or two ever having to be replaced. There is a How-To Doc on how to do it though. Good luck.
Old 11-27-2006, 07:09 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Out of the 9 Subarus I've owned I've never replaced a fuel pump in a single one of 'em. What kills them over anything else though would be the decomp. of the rubber clogging it. I wouldn't replace it if I were you.
Old 11-27-2006, 08:00 AM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
I haven't ever replaced a fuel pump on either SVX. Each one is well over 200,000 miles.
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 11-27-2006, 08:41 AM
dcarrb dcarrb is offline
I had a fuel pump fail suddenly on my old '86 GL wagon as it approached 200,000 miles, so I've slated fuel pump replacement as SVX preventive maintenance somewhere in the neighborhood of 180,000.
dcb
Old 11-27-2006, 04:55 PM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Never
I have never replaced one on any of my cars or heard of anyone that did. And that is not the whole story---I would never replace one unless it failed. Given the location of the fuel pump and the required access on the interior right behind the rear seat, I think it is best NOT to disturb it unless absolutely necessary. What if you did not get it sealed properly?????
Lee
Old 11-27-2006, 05:14 PM
SVX Voyeur
Wow. That is amazing! Thanks for the feedback. Maybe I'll hold back with my low Miles
50% Boxer
Old 11-27-2006, 06:27 PM
benebob's Avatar
Lee
Lee, its the best located fuel pump I've ever come across and I've owned EA-81s with their nice exterior mounted pumps! You have to lie on your back though to work on those. Its as easy as putting a lid on (literally) to get reseal.
Old 11-28-2006, 06:08 AM
Gets awfully quiet when a fuel pump fails.
Maybe I shouldn't draw parallels between two vastly different Subaru products, but that's my experience, and I'm sticking with it. If the car in question is a daily driver, 'tis better to change pumps and hoses and belts and alternators and such before they leave you stranded.
dcb
Old 11-28-2006, 06:20 AM
SVX_MY_BABY's Avatar
I'd be more worried about the fuel and brake lines rusting out above the fuel tank. It's the one area you can't get at with rust protection. I'm sure they use a lot of salt on your roads. I had a Volvo 740. Seems all Volvos are known for fuel and water pump failures around 100k km.
Old 11-28-2006, 06:23 AM
benebob's Avatar
dcb
Why not replace the car while your at it? Wear items yes but my guess is your GL pump failed because it was 3/4 clogged and overworking for 50k (in other words you neglected your maintainance of your car) before it failed. So long as the rubber is good, strainer is kept clean and you're electrical conacts kept free from corrosion a Subaru fuel pump should outlast the engine and body of a car.
Old 11-28-2006, 07:41 AM
I need you to fill me in on how to maintain a car to prevent fuel pump failure.
dcb
Old 11-28-2006, 08:02 AM
benebob's Avatar
dcb
Can you read? I explained it already. Not ragging on you in the least but your logic is quite flawed unless you want to replace every part on the car. Honestly, with the SVX you're better of replacing the tranny as preventative maintaince rather than replacing the fuel pump.
