Old 10-26-2006, 02:16 AM
Are our cars that fast???
First of all, this is not a racing thread, pls I really hope it will be considered professionally as such.
I convinced my friend recently to purchase a mint and exceptionally low mileage 97' Impreza GT Turbo (or WRX in your language with 25K certified miles!!!) at a slight higher price (the car was sitting in a private garage and barely being driven).
Because he is so obsessed, he asked to change the whole exhaust system (was a little rusty) and overhaul the entire turbo unit, change brake pads, rotors, gas shocks, oil, spark plugs, short shifter, etc... costing him near $2K.
After that we went to test his car and I took mine, cruising near each other on the highway at around 50mph, I signaled him to push it. We both engaged at second gear and high rpm (I saw 6500 on my odometer) and we pushed both ours. I thought he should pass me easily especially on low speeds, but he kept by my side until we reached high speeds when I started taking pace ahead of him...
After another turn, the same happened! we both couldn't figure it out (he reached 7000rpms!), he has a lighter car with approx the exact amount of power... and BOOSTED with an excellent setup! He is also running on 1 Bar of boost instead of the 0.8 Bar originally set by Subaru.
My question is: IS that FREAKING NORMAL??? Are our cars that fast???
P.S: He is an excellent driver, he used to own a 1996 M3 with 321hp's but got fed up with RWD cars
I say it again, THIS IS NOT A RACING THREAD, I DON'T WANT IT TO BE CONSIDERED AS SUCH, FURTHERMORE WE HAVE SAME DRIVING RULES AS THE GERMAN AUTOBAHN (NO RULES!!!) NEVER TRY IT OVER THERE... PLEASE
Old 10-26-2006, 03:29 AM
Pure_Insanity8's Avatar
Pure_Insanity8 Pure_Insanity8 is offline
Send a message via ICQ to Pure_Insanity8 Send a message via AIM to Pure_Insanity8
His car should have been quicker. Do you know what version engine his WRX has? Could have been the 280 bhp EJ20K, 250 bhp EJ20G, or 218 bhp EJ20K. I guess if he had the 218 bhp version, your scenario seems plausible.
Hope your thread doesn't get locked for "racing" since it is still on public access roads and therefore dangerous.
-Aaron
SVX: '92 Dark Teal 101k
'97 Legacy GT Wagon: dead
'99 Civic Si: daily driver... stolen and stripped with all my tools!
'92 Yamaha FZR 600: garage
2011 Jetta: Daily disappointment
Old 10-26-2006, 05:25 PM
I don't think that would be considered a dangerous action, in Lebanon, he didn't shoot any one.
Old 10-26-2006, 07:12 PM
It's Just Eric's Avatar
Missing in action
I suppose the svx's long legs make up for the overall power advantage. Keep in mind his final drive and tire circumfrence, as well as the effect of drag when figuring who's faster after a certian point.
Im quite sure the lighter more powerful car would have you off the line easilly, but with a rolling start as such, it about evens out
R.I.P Cool Signature.
Old 10-26-2006, 09:19 PM
KevinM KevinM is offline
I can't compare with an older WRX, but my fiance has an '02 WRX with a light tune and it KILLS my SVX. It is really no contest, so something may not be right with your friend's car.
1992 Teal LS-L w/ 150k miles bought March '06 ... stock
Old 10-26-2006, 09:31 PM
gest24's Avatar
$ gest24 $ gest24 is offline
#1 6MT In Cali
What about my SVX???
Sand Diego SCCA Solo 2 #308
RIP
84 VW Scirocco
02 WRX
Check My New Homepage..
Old 10-26-2006, 10:26 PM
my wife's '02 WRX made my SVX seem slow, but now my LGT makes her WRX seem slow.
the balance of power (me having more ) is restored.
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2013 G37xS (Obsidian Black)
Old 10-27-2006, 06:54 AM
shotgunslade's Avatar
On the race track, my car is a little bit faster down the straight than stock 02-03 WRX's. This would be accelerating from 50-60 mph to 100+. Pulls away faster at the higher speeds. Probably would get them from very low speeds also, before their turbo's have a chance to spool up. They actually should be best coming out of a medium speed turn, as their rpm's would already be high. Even so, I'm fastar, but not stock
Old 10-27-2006, 07:51 AM
drivemusicnow's Avatar
Poor College Racer
No.
But then again I don't think WRXes are "that fast" either... so who knows.
(slowly waiting for the day I actually get to drive my "that fast" car)
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Old 10-27-2006, 08:33 AM
mikecg's Avatar
mikecg mikecg is offline
Mine is. And I will have the dyno numbers and a drag slip to prove it over the next few weeks.
Old 10-27-2006, 06:43 PM
mine will be once I get the tuning figured out...or I scrap it
Old 10-27-2006, 07:38 PM
sicksubie's Avatar
are there any guesses at what you might see at the track for a 1/4 time, tom or mike?
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 10-27-2006, 08:35 PM
as it is, my car would pull a 14.5.... Yeah i may be a little pissed
Old 10-27-2006, 10:09 PM
sicksubie's Avatar
14.5 on 12lb of boost? What am I missing?
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 10-28-2006, 07:58 AM
mikecg's Avatar
Have you run it at the track?
I pulled off a 14.08 with a 9lb pulley, a slipping belt and the older software. The version of software you have should do you better then that.
I'm hoping to make a couple passes tomarrow. If the weather permits.
