Help Tranny!!
This just all the sudden started happening.
i'm at a light in town and i'm in the 3rd gear selector light turns green and i stomp it Half throttle. the RPM's reach abou 1800 -2000 then it takes off with a screeetch of front tires... mine is AWD. 94 Lsi hmm could it be the tourqe converter? |
AHHHH i don't know what it could be.
i was on gravel and i punched it!!. what happened well it went from the wheels that slipped to the same slipping wheels.?!! Sh*t i held the E-brake. and it stayed there and spun front tires?!! ok now i'm pissed it's probly the rear clutch packs right? how hard are they to replace.? Damn mazda trannys |
-Mike |
Ahhh tranny
With all the horror stories i've heard
about rebuild of these trannys. where do i go and who will do the best job? about what's the normal price range? I'm in the Chair Force and i don't make that much money |
Re: Ahhh tranny
-Mike |
.... transfer clutch
The tranny isn't blown. Just the the clutches in the tail section. I had mine R/R on warrenty. I would guess $600-700 depending. You have to pull it apart. I'm sure others will chime in. Hope you find a good dealer. B.
Well this is what you do. Measure the tranny oil pressure in the transfer housing. If you have pressure the clutches are shot. If you don't have pressure then the transfer solenoid / valve assy is bad.
I assume you have no warning power light on? If the clutches are bad you have a lot of fiber and metal in your tranny now. I think I would not drive it in this case. If the transfer valve/solenoid is bad it can be replaced. The car can be driven. Don't stomp on the accel a lot or you will reck the front dif. |
I thought the transfer case didn't actually use friction material? On mine, it was actually the gear on the rear output shaft that broke off. The dealership wanted to replace the tranny, but I let AAMCO try and fix it for $600. They replaced the shaft and it's still running after 2.5 years 40-50k miles.
KuoH Quote:
One suggestion, put in the FWD fuse. It may or may not help, but I did it on the basis that it would stop trying to put power to the rear wheels and make things worse. It might not help, but it couldn't hurt to try.
KuoH |
The gear you are talking about actually provides the power to the front wheels.
Yes, there are clutchs in the transfer housing. Putting in the FWD fuse will slow the car down and that will help save the front dif. |
Well last night i changed the
AFT fluid and the filter. what happens??... Mother F*@*# 94 (*#($*)@ SOn of A @(#*-$) tranny don't work. anymore. it's slippin so bad i can't move i had to drive backwards to my house. ahhhhhh i need a new tranny . how much for a 5 speed? |
Well the mechanic tried to explain a little about it to me, but I didn't catch everything. Still, the gear "was" attached to the shaft going to the rear diff. How does that provide power to the front wheels?
KuoH Quote:
Do you have a service manual?
Nope. That's why I asked. I'm just trying to think through in my mind how a gear attached to the rear shaft, hence the rear diff, can distribute 90% of the power to the front wheels?
KuoH |
I tried to make a copy with my camera but it came out real bad.
I'll try to explain. The main shaft thru the tranny starts with the Torque Converter and ends with the shaft to the rear wheels. All the clutches, planetary gears etc are located along this shaft between the TC and the rear wheel shaft that comes out the back of the tranny. It is a straight line from the TC to the rear of the tranny. The last sets of clutches on this main shaft is the transfer clutches for the rear wheels. Right in front of the transfer clutch is the reduction gear. This reduction gear drives a gear on another shaft that goes from the back of the tranny to the front differential. |
Thread Tools | |
Display Modes | |
