Old 07-26-2006, 03:49 PM
Looking for part numbers
I'm looking to confirm the part numbers for the following:
- R134 A/C sticker for the top radiator mount
- Evaporator sensor (to fix my code 14)
- 2 clips to hold the plastic "side garnish" on. (The 2 that are hidden by the front of the door by the hinges)
Old 07-27-2006, 01:00 PM
No one knows?
Old 07-27-2006, 02:14 PM
The only R134A AC label I can find is 73090PA030
The 2 screws for the garnish should be 91017PA210
I know the sensor that gives you a code 14 (shorted intake sensor), is installed on the evaporator assembly case (See FSM Section 4-7, pg.20) Since the code says that this sensor is bad and not working anyway, try to pull it and see if there is a PN on it.
FSM 4-7, pg. 114-115 gives you instructions on how to check to see if it is the sensor, the harness, or the audio amplifier (which is connected to the rear of the AC control panel)
Wish I could be more help.
Old 07-27-2006, 02:35 PM
I have the FSM's and I've verified it is the sensor that is bad.
I would pull the sensor except for the fact I would need to remove the evaporator assembly and that would require evacuating the system. I would rather have a replacement sensor for when I get that done.
There are 2 sensors on the evaporator but no diagram on subaruparts.com so I don't know which one is which.
As for the A/C label I found 2. One is the one you mentioned the other ends in 020. I think the 2 screws/clips are different between top and bottom. Maybe I'll take a picture of the 2 I need.
Old 07-27-2006, 07:50 PM
michael's Avatar
michael michael is offline
What Potholes ???
I believe there are 3 parts for the clips needed. I know that one of the clips account for 2 part #'s one is 91059PA040- this is a female end and 91017PA180- this is the male.
Old 07-27-2006, 08:15 PM
michael's Avatar
What Potholes ???
https://www.1stsubaruparts.com/partscat.html
has them but no part #'s
I made mine
Old 08-01-2006, 09:35 AM
Thanks for the info. The attached photo is for the R12 sticker. I need the R134 sticker.
Old 08-02-2006, 12:55 AM
Where you guys get your part numbers from??? I need to look up some part numbers for my car and I do not want to bother people all the time with them, any help on that??
Old 08-02-2006, 05:20 AM
michael's Avatar
What Potholes ???
www.subaruparts.com they are for SOA parts tho.
