Old 07-22-2006, 07:29 PM
DanSVX94's Avatar
DanSVX94 DanSVX94 is offline
Ren-Ma Osu
glove box light bulb -- how to change?
Anyone know how to remove the glove box light bulb -- my fingers are too big. I need to get a new bulb. It the bulb a screw in or push down and twist?
Also I noticed a piece of elastic that's obviously there to hold owner's manual. Never noticed it before! Cool.
Where is the place to plug in a cellphone? I heard the svx came pre wired for mobile phones.
Old 07-22-2006, 07:53 PM
berger's Avatar
berger berger is offline
Send a message via ICQ to berger
i never knew the glove box had a light globe!
Old 07-22-2006, 07:56 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
it should be pull out.... i thought that cell phone wiring thing never made it past prototype
- John
Old 07-24-2006, 12:09 PM
Cell phone wiring in in the trunk behind the trim on the passenger (right) side.
The bulb for the glove compartment is your standard wedge bulb (194?) with a green "condom" on it for colour. You can remove the bulb with a pair of needle nose pliers and use the same pliers to carefully position the replacement for installation. Much patience is required for installation.
Old 07-24-2006, 02:46 PM
DanSVX94's Avatar
Ren-Ma Osu
what do you do with the cell phone wiring? What does it look like -- a socket or just wires?
I cut off a wide pen cap and taped it to tweezers so the bulb would sit in the cap and I was able to replace the bulb this way -- however the green condom on the old bulb broke, so I'm expecting some little led's in 9 months.
Old 07-24-2006, 03:21 PM
Originally Posted by DanSVX94
however the green condom on the old bulb broke...
That just make the glove box light a little brighter.
On a related note, if you change the little bulb which illuminated the hazard flasher bitton in the dashboard, you will notice it has a green condom on it, which causes the hazard "triangle" to be softly illuminated. If you remove the green condom from the replacement bulb, the red triangle becomes much brighter.
Old 07-24-2006, 04:31 PM
The cell phone connector is a "male" plug with 4 wires I believe.
Old 07-26-2006, 12:49 AM
I have a picture of it and will try to post it later.
