Old 06-23-2006, 09:56 AM
AJ4U2's Avatar
AJ4U2 AJ4U2 is offline
Wink Gas
I got 2 92's AWD I get about 27 to 29 and my 94 FWD is still about the same so i think it has to do with condition of the engine and driving habits.
Just my 2 cent, 91 fuel not cheap you just got to pay if you want to play.
Old 06-23-2006, 10:49 AM
TheSTig
Originally Posted by intelisevil
Sounds like you have a problem.
He lives in CO. That means he's probably going up and down a lot more than you. I'm guessing that's the reason. As for improving your mpg...
1. Overinflate your tires on long trips.
2. Put synthetic in your front and rear diffs.
3. Clean air filter.
4. Run some xylol or toulene through your tank sometime to clean out the gunk.
5. Draft SUVs. heh.
6. Keep your windows up and sunroof closed.
7. Install a home depot 'chin spoiler' lip thing from landscaping edging. Should help a tiny bit.
8. Get to know your transmission, and use as little gas as possible when maintaining speed, and sort of vary your foot when accelerating to help keep hte engine from bogging or over revving.
Old 06-23-2006, 10:52 AM
TheSTig
Originally Posted by svx_commuter
3. Anytime I go down a hill I take my foot of the gas and coast as long as I can. The SVX just loves to coast. I am amazed at how easily the SVX will coast and maintain speed. I keep the car moving and out of 1st gear by planning ahead, braking at higher speeds and then coasting waiting for the light to turn green so that I do not have to stop. It takes a lot of energy to get the car moving from a stop. I make space in front of the SVX for coasting. The SVX is not made for sitting still it wants to move.
That's true. It weighs a lot, and has awesome aerodynamics. There's a hill on 90 where I live near brookfield and I put mine in Neutral and actually pass people. :P
Old 06-23-2006, 11:45 AM
You actually burn more gas in neutral as opposed to coasting in gear. Reason: the engine needs gas to keep from stalling in neutral.
Old 06-23-2006, 12:06 PM
TheSTig
But coasting in gear= slower acceleration and more drag.... so you coast less....hrm... a predicament. Sounds like we need to call mythbusters.
Old 06-23-2006, 01:23 PM
intelisevil's Avatar
<<<Alcyone
How is our transmission oil pump driven? I don't claim to be a transmission expert.
If it's crankshaft driven only (like most), do we have enough ATF pressure to keep circulating the fluid when coasting in Neutral? In Neutral, the wheels are still causing some internal transmission parts to move.
Engine speed = idle, Tranny internals = 60 MPH? This can't be a good thing.
Knowing the inherent weaknesses of our transmissions, I coast down hill in gear. A few more cents in fuel costs now, hopefully stretching out the time for the inevitable tranny rebuild/replacement . . .
Just my $.02.
Dan
Old 06-23-2006, 01:50 PM
Yoda3000's Avatar
Yoda3000 Yoda3000 is offline
(This account is in rememberance of)Duct Tape Man
Send a message via AIM to Yoda3000
Wow, I never thought about that stuff!
anyway, I've been delivering pizza this summer: Stop and go traffic, car on an off constantly, and I drive what most would call very agressively. Over the last 1500 miles (month) I've got an average mpg of 20.42, ranging between 18.65 and 23.15 mpg.
I used zmax with my last mobil-1 oil change, and Just last week I upped the pressure in my tires, which I think helps. I also use 91 octane, which is pretty rare here in NM.
I also never use the A/C (that doesn't work) and windows usually open (90+ degree weather)
Early deceased SVXWN Member
July 1986 -- February 2007
Michael - Duct Tape Man
1992 Burgundy SVX LS-L, 138K: Brembo Slotted/Drilled Rotors, B&M Tranny Cooler and Filter, SmallCar Shift Kit
1992 Burgundy SVX LS-L, 123K: DEAD FROM FATAL HAIL DAMAGE, Parting out so PM me if you need something.
"It's only after we've lost everything that we're free to do anything" - Fight Club
"This is not my life, this is not my home, this is not me. I HATE THIS!" - Static X
Old 06-23-2006, 01:55 PM
TheSTig
Just my $.02.
Dan
I'm sure if that were a huge problem it would say something about it in the SVX manual.
Old 06-23-2006, 04:02 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Ft. Collins is flat, like Kansas. When I lived in CO mountains my '92 got 31mpg hwy, 30 with the bra on and 16-23 in town. Not much difference at lower altitude, read on:
Thin air = more mpg, no doubt about it. Up and down doesn't make any difference - $$ up, no $$ going down.
My motorhome in the mountains would get 15mpg. In Missouri it dropped to 9mpg. Air drag is a huge factor. SVX has low drag so it isn't an issue.
Old 06-23-2006, 05:54 PM
<<<Alcyone
You're starting to sound like a lawyer . . . I'm surprised our bad word monitor allows that word!
The word according to Subaru:
"All-Wheel Drive vehicles cannot be towed with any wheels on the ground. The vehicle can only be towed on a trailer with all four wheels off the ground and the transmission in park. Front-Wheel Drive vehicles can be towed with front wheels off the ground or all four wheels off the ground and transmission in park."
I know this isn't exactly the situation I described above but it makes me believe that the oil pump is crank driven. If it was internally driven, I would think towing with all four wheels on the ground wouldn't be quite as bad.
I'd like to see an automatic transmission expert chime in here before I subject my tranny to the experience.
Dan
Old 06-23-2006, 06:17 PM
I always thought it's driven by the torque converter.
Old 06-23-2006, 06:56 PM
TheSTig
It is. Like on most engines. We were talking about hte transmission.
Old 06-24-2006, 12:49 AM
CDG's Avatar
CDG CDG is offline
No front plate on My SVX
Send a message via MSN to CDG
I'm not sure what my milage is but I get 200 miles to the tank, and its past E but no light on when I fill it up.
I'm paying $73 per fillup these days. Thats about 57 litres, average. 1Imp Gallon ~= 4.546 litres, 1US Gallon ~=3.983 litres, fyi.
I only drive in the city, occasional highway, if I'm lucky, and there's only 1 in Vancouver.
My tires are stock and I keep them at 39(fr) and 36(rr). Maybe I should bump then up a little more. Except the roads here suck,but with the 2010 Olympics coming things are shaping up
as for coasting in neutral: I think the trany's getting plenty of lube, don't worry, doesn't the torque converter force fluid flow???
Chris G
92 Pearlie, sold @ ~209k miles. Now owned by Tim.
Current Ride, 1985 Honda Aero 80, stock 3024 klms
Old 06-24-2006, 02:12 AM
SVX10's Avatar
SVX10 SVX10 is offline
Fighting with electricity
With my 92 when I had a freshly rebuilt AT and KC intake in wheel well I got 31MPG doing a full highway trip going 70-75. That was the highlight of my life
Now with a 5MT and the STi ratios (stock 5th) doing about 70% highway I get 21-22MPG.
Man I wish Subaru would've been on top of variable timing/lift back in '92. They were on top of all the other technologies that have just recently become popular
Old 06-24-2006, 02:57 AM
Jade Dragon's Avatar
Jade Dragon Jade Dragon is offline
Don't screw with the Dragon
Send a message via AIM to Jade Dragon Send a message via Yahoo to Jade Dragon
yeah, fort collins isnt too up/down.
->Austin<-
1992 Pearlie (Pearl): motorsport exhaust kit (Wife's)
1994 Red FWD (Roxi): Custom X exhaust
